Thread with vTaskDelay() runs periodically, but vTaskDelayUntil() seems to block the Thread indefinitely
Namaste @rtel and @jefftenney,
On the breakpoint and debug recommendation, I’d like to mention that I’m using the Eclipse IDE for code browsing and, compiling the code over command line.
I was facing issues when configuring the Eclipse IDE for using the IDE’s Debug and Build options. I left it half way back then. But that’s a separate issue so won’t get into that.
I’ll have to explore the ESP-IDF’s idf.py tool to use the break-point and debug options over the command line. I’m not sure how soon I shall be able to revert with my observations.
Thank you again!
Thanks | Regards,
Dipen
