Thread safe memory allocation
richard_damon wrote on Friday, August 09, 2019:
By default, new/delete are often not thread safe in a FreeRTOS app because the basic malloc and free are not thread safe.
Some embedded libraries have hooks that can be defined to make these functions thread safe. For example, newlib, if it was compiled properly, will use the functions __malloc_lock() and __malloc_unlock() to allow you to protect the library from re-entrancy. I often define them with a call to vTaskSuspendAll() / vTaskResumeAll() to provide that protection.
You also may be able to replace them with alternate functions that do what you want. The one issue here is you need to dig into the library, as sometimes malloc/free are just thin wrappers around something deeper internally, and parts of the library may just call those internals, so THOSE are what willl need to be replaced.
If you are only worried about fixing new/delete, then you can over ride the implementation of those to use a thread safe allocator, (be sure to get new[] and delete{} too), but this will not fix usage of malloc and free.
configUSE_NEWLIB_REENTRANT is a flag that creates a structure for every thread that contains a bunch of internal state used by some functions in newlib, depending on some library options, this can be fairly small or quite big (as it can contain the File IO Buffers). Programs designed for small systems often don’t use the parts that need that structure on a per-task basis, as they don’t use that functionality. If you do use it, you need to define that to 1 to get the needed thread safety, or manually protect those parts of the library from reentrancy.
