TCP Refusing FIN
Thanks again for all the support. I am assuming that the suggested change is considered a workaround for now correct? Is this going to be considered a bug and will a more thorough fix be merged into the TCP library? For me its not too bad to essentially use a 1 line change fork in the short term, but long term it would be better to be able to use the standard release.
