TCP/IP issue on STR912
dotdotdog wrote on Monday, September 07, 2009:
I am using uIP on STR912, connected with a PC/104AB control board. there are 4 motor encoders data-in from PC/104AB to the main board.
I use the TCP/IP protocol to get the Encoder values from the data bus, but I encounter the problem:
The Encoder reading task runs every 10ms, it returns correct value while the motor is running. The TCP/IP task starts every 0.5 sec. once the task starts, the value from Encoder is boomed to an abnormal one. Anyone here met this problem before?
Thanks,
Rickey
davedoors wrote on Monday, September 07, 2009:
Richard - can you delete duplicate posts?
