@hs2
There is a very strange phenomenon,I have set up three functions like this:
void Delay_test(void*p)
for(;;)
vTaskDelay(10);
void doble_loop_delay_test(void)
int i = 1;
for(;;)
can_send(CAN0, 0x0001, 7, 0x04030201, 0x08070605, 5);
vTaskDelay(10);
if(i <= 10)
for(;i <= 10;i++)
can_send(CAN0, 0x0001, 7, 0x04030201, 0x08070605, 8);
vTaskDelay(10);
i = 1;
void t_speed_test(void* pm)
t_param_t* param = pm;
const TickType_t xDelayTime = pdMS_TO_TICKS(10);
TickType_t xLastWakeTime = xTaskGetTickCount();
Bool new_progress = true;
int S/* = (*param).target_position - (*param).current_position*/;
int Am/* = (*param).max_acc*/;
int Vm/* = (*param).max_speed*/;
if(param -> isNewPosition)
S = (param -> target_position) - (param -> current_position);
Am = param -> max_acc;
Vm = param -> max_speed;
param -> isNewPosition = false;
while(1)
if(new_progress)
float Smin = abs(Vm * Vm / Am);
if (S < 0)
Am = -Am;
Vm = -Vm;
S = -S;
float t1, t2, t3;
if (S > Smin)
t1 = (float)Vm / (float)Am;
t3 = t1;
t2 = (S - abs(Vm) * t1) / abs(Vm);
float Vm0 = sqrt(S) * sqrt(Am);
t1 = Vm0 / abs(Am);
t3 = t1;
t2 = 0;
float x1 = 0.5 * Am * t1 * t1;
float x2 = Am * t1 * t2;
float s;
for(int i = 10; i <= (int)((t1 + t2 + t3) * 1000); i += 10)
if (i / 1000.0 < t1)
s = 0.5 * Am * (i / 1000.0) * (i / 1000.0);
else if (i / 1000.0 >= t1 && i / 1000.0 < t1 + t2)
s = x1 + Am * t1 * (i / 1000.0 - t1);
s = x1 + x2 + Am * t1 * (i / 1000.0 - t1 - t2) - 0.5 * Am * (i / 1000.0 - t1 - t2) * (i / 1000.0 - t1 - t2);
can_send(CAN0, 0x0311, 6, (uint32_t)s, 0, 4);
// Can_Send_IntData(CAN0 , 0x0311 ,(uint32_t)s , 0x00000000);
//vTaskDelay(10);
vTaskDelayUntil(&xLastWakeTime, xDelayTime);
vTaskDelay(5);
And the parameters used are like this:
typedef struct
int max_acc;
int max_speed;
Bool isNewPosition;
uint32_t current_position;
uint32_t target_position;
uint32_t current_speed;
uint32_t target_speed;
}t_param_t;
void can_send(Can *p_can, uint32_t ms_id, uint32_t mb_code, uint32_t datal, uint32_t datah, uint32_t digit)
p_can -> CAN_MB[mb_code].CAN_MMR = CAN_MMR_PRIOR(0) | CAN_MMR_MOT_MB_TX;
p_can -> CAN_MB[mb_code].CAN_MID = CAN_MID_MIDvA(ms_id);
p_can -> CAN_MB[mb_code].CAN_MDL = datal;
p_can -> CAN_MB[mb_code].CAN_MDH = datah;
p_can -> CAN_MB[mb_code].CAN_MCR = CAN_MCR_MDLC(digit) | CAN_MCR_MTCR;
//xSemaphoreHandle t_target_Mutex;
//xSemaphoreHandle t_current_Mutex;
//can_rxmb_data_t rx_data;
t_param_t t_param;
//S_Motion_Plane_In_t input_param;
int main (void)
WDT->WDT_MR = WDT_MR_WDDIS;
/* Insert system clock initialization code here (sysclk_init()). */
sysclk_init();
board_init();
ioport_init();
delay_init(sysclk_get_cpu_hz());
t_param.current_position = 0;
t_param.target_position = 10000000;
t_param.max_acc = 1000000;
t_param.max_speed = 500000;
t_param.isNewPosition = true;
BaseType_t a = xTaskCreate((void*)Delay_test, "delay_test", 100, NULL, 3, NULL);
//BaseType_t b = xTaskCreate((void*)doble_loop_delay_test,"dldt",100,NULL,5,NULL);
BaseType_t b = xTaskCreate((void*)t_speed_test, "t_speed_test",500,&t_param,5,NULL);
if(a && b)
vTaskStartScheduler();
The specific situation is: when functions Delay_test and doble_loop_delay_test are executed simultaneously as tasks, the program runs normally , and if I only run the task of function t_speed_test, the program can also be used normally. When functions Delay_test and t_speed_test are executed simultaneously as tasks, the program is stuck in the function portFORCE_INLINE static void vPortRaiseBASEPRI( void ) when entering the delay function for the first time.I confirm that there are no other interrupts used during the execution of the function, and I will continue to try to trace the stack
