Synchonisation in Trustzone secure world by callbacks to non-secure world
I am using Trustzone because the usage of the DSP needs security. To use the DSP from the non-secure world, the SW calls a non-secure callable function in secure world that sends a command to the DSP. Then in secure world we call a callback function in non-secure world that will do a ‘semaphore take’ so that it blocks on a samaphore until the DSP finishes the operation. When the DSP finishes the operation it will send an interrupt to the M33 that arrives in the secure-world. The secure world will then again call a callback function in non-secure world that does a ‘semaphore give’ operation. This unblocks the task that was waiting on the result of the DSP.
In an implementation with a spin-loop to wait on the DSP result everything seems to work fine. But that is a waste of cpu cycles and power. The semaphore implementation is sort of working. It can work for a few minutes or a few hours but then it deadlocks. The ‘give’ for the ISR does not unblock the task that is blocked by the ‘take’.
