westmorelandeng wrote on Tuesday, March 24, 2015:
And, for something completely different - when I define all of these to run:
vStartIntegerMathTasks( tskIDLE_PRIORITY );
vStartDynamicPriorityTasks();
vStartBlockingQueueTasks( mainBLOCK_Q_PRIORITY );
vCreateBlockTimeTasks();
vStartCountingSemaphoreTasks();
vStartGenericQueueTasks( tskIDLE_PRIORITY );
vStartRecursiveMutexTasks();
vStartPolledQueueTasks( mainQUEUE_POLL_PRIORITY );
vStartSemaphoreTasks( mainSEM_TEST_PRIORITY );
vStartMathTasks( mainFLOP_TASK_PRIORITY );
vAltStartComTestTasks( mainCOM_TEST_PRIORITY, mainCOM_TEST_BAUD_RATE, mainCOM_TEST_LED );
/* Create the register test tasks, as described at the top of this file. */
xTaskCreate( vRegTestTask1, "Reg1...", configMINIMAL_STACK_SIZE, NULL, tskIDLE_PRIORITY, NULL );
xTaskCreate( vRegTestTask2, "Reg2...", configMINIMAL_STACK_SIZE, NULL, tskIDLE_PRIORITY, NULL );
/* Create the software timer that performs the 'check' functionality,
xTimer1 = xTimerCreate( "CheckTimer", /* A text name, purely to help debugging. */
( mainCHECK_TIMER_PERIOD_MS ), /* The timer period, in this case 3000ms (3s). */
pdTRUE, /* This is an auto-reload timer, so xAutoReload is set to pdTRUE. */
( void * ) 0, /* The ID is not used, so can be set to anything. */
prvCheckTimerCallback /* The callback function that inspects the status of all the other tasks. */
if( xTimer1 != NULL )
xTimerStart( xTimer1, mainDONT_BLOCK );
/* Create the software timer that performs the 'LED spin' functionality,
xTimer2 = xTimerCreate( "LEDTimer", /* A text name, purely to help debugging. */
( mainLED_TIMER_PERIOD_MS ),/* The timer period, in this case 75ms. */
prvLEDTimerCallback /* The callback function that toggles the white LEDs. */
if( xTimer2 != NULL )
xTimerStart( xTimer2, mainDONT_BLOCK );
/* The set of tasks created by the following function call have to be
created last as they keep account of the number of tasks they expect to see
running. */
// vCreateSuicidalTasks( mainCREATOR_TASK_PRIORITY );
vTaskStartScheduler();
for ( ;; );
The IDLE (hook) task runs! Hmmm.
