Strugling with porting Eth drivers for STM32H563ZI
Hello, I have checked all the hardware (RMII vs MII) everything is set up correctly. This board has been tested with LWIP and worked with all the same configurations, I just got sick of integrating LWIP and free RTOS to work for me. As I mentioned when replying to @HTRamsey now I am seeing network traffic that the board is receiving, which is definitely a step closer than before.
I still dont see the board sending out any packets on wireshark or see it connected to the network even when using a static IP.
Just an update, I have gotten the DHCP requests to work as well as the transaction to complete and now the board shows up on the network.
Glad that you worked it out. It will be helpful to others if you share your solution too!
I have marked the comment from @HTRamsey as his NetworkInterface.c file is what got it working. Other than that the only issues I was having was with our custom board and the way in which I initialized the network stack. his code did work out of the box.
