Hi @aggarg I will be able to check the TCB latter. Is there anything special to monitor on the TCB?
Regarding my previous post I found that according to the reference manual DMA2_Stream0
has a priority of 63
whereas ucMaxSysCallPriority
goes from 32
to 144
and litteraly no interrupts could have this value.
So the big question is why does it change?
I also checked that my stack arrays are not too big, with a stack size of 500 and 4 bytes per word then it should fit into the 128Kbytes of RAM I got.
