chdo wrote on Wednesday, May 22, 2013:
I wrote this program but when i compile i get this error:
‘TIM2_IRQn’ could not be resolved
What am i missing please?
/* Standard includes. */
#include <string.h>
#include <stdio.h>
/* Scheduler includes. */
#include “FreeRTOS.h”
#include “task.h”
#include “queue.h”
#include “semphr.h”
#include “stm32f10x.h”
#include “stm32f10x_conf.h”
#include “stm32_eval.h”
#include “partest.h”
#include “STM3210C_EVAL/stm3210c_eval_lcd.h”
/* Task priorities. */
#define TASKPRIORITY1 (tskIDLE_PRIORITY + 1)
#define TASKPRIORITY2 (tskIDLE_PRIORITY + 2)
#define TASKPRIORITY3 (tskIDLE_PRIORITY + 3)
#define mainFLASH_TASK_PRIORITY ( tskIDLE_PRIORITY + 1 )
/* The rate at which the flash task toggles the LED. */
#define mainFLASH_DELAY ( ( portTickType ) 25 / portTICK_RATE_MS )
/* The number of nano seconds between each processor clock. */
#define mainNS_PER_CLOCK ( ( unsigned portLONG ) ( ( 1.0 / ( double ) configCPU_CLOCK_HZ ) * 1000000000.0 ) )
/* The length of the queue used to send messages to the LCD task. */
#define LCD_QUEUE_SIZE ( 3 )
int ledInitTask(void *pParams);
void ledTaskFunc(void *pParams);
void lcdTaskFunc(void *pParams);
typedef struct {
unsigned short toggleFrequency;
} LedInitParams;
typedef struct {
char msg;
}LcdMsg;
* Configure the clocks, GPIO and other peripherals as required by the demo.
static void prvSetupHardware(void);
* The LCD is written two by more than one task so is controlled by a
* ‘gatekeeper’ task. This is the only task that is actually permitted to
* access the LCD directly. Other tasks wanting to display a message send
* the message to the gatekeeper.
extern int sprintf(char *out, const char *format, …);
/* Semaphore utilise pour le cas 0*/
xSemaphoreHandle xSemaphore0;
/* The queue used to send messages to the LCD task*/
xQueueHandle g_lcdQueue;
int main(void) {
prvSetupHardware();
setbuf(stdout,NULL);
/* Start the scheduler. */
printf("########################## MINI PROJET CS530 ################\\n");
vTaskStartScheduler();
xTaskHandle xLed,xbutton,xledInitTask,xledTaskFunc;
/* Will only get here if there was not enough heap space to create the
idle task. */
return 0;
/* creation semaphore et taches , */
xSemaphore0 = xSemaphoreCreateCounting( 1,0);
if( xSemaphore0 != NULL )
printf(“DEBUG : CREATION SEMAPHORE SUCCED\\n”);
/* TASKPRIORITY1 = (tskIDLE_PRIORITY + 1) et TASKPRIORITY1 = (tskIDLE_PRIORITY + 2) */
/* tache de haute priorite */
xTaskCreate(ledTaskFunc,“TASK1”, configMINIMAL_STACK_SIZE+1000 , NULL, TASKPRIORITY1,&xledTaskFunc);
/* Create the queue used by the LCD task. Messages for display on the LCD
are received via this queue. */
g_lcdQueue = xQueueCreate( LCD_QUEUE_SIZE, sizeof( LcdMsg ) );
xTaskCreate(lcdTaskFunc, “Task2”, configMINIMAL_STACK_SIZE * 2, NULL, 2, NULL);
static void prvSetupHardware(void) {
USART_InitTypeDef USART_InitStructure;
/* Enable GPIOA, GPIOB, GPIOC, GPIOD, GPIOE and AFIO clocks */
RCC_APB2PeriphClockCmd(
RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
| RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE
| RCC_APB2Periph_AFIO, ENABLE);
/* Set the Vector Table base address at 0x08000000 */
#ifdef IAP_VECT_TAB_RELOCATE
NVIC_SetVectorTable(NVIC_VectTab_FLASH_RELOCATED, 0x0);
#else
NVIC_SetVectorTable( NVIC_VectTab_FLASH, 0x0 );
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
/* Configure HCLK clock as SysTick clock source. */
SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);
/* Configure UART */
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl= USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
STM_EVAL_COMInit(COM2, &USART_InitStructure);
unsigned long n;
LedInitParams *params;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
NVIC_InitTypeDef NVIC_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
params = (LedInitParams*)pParams;
/* Enable GPIOD, GPIOE clocks */
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOD, ENABLE );
/* Configure PD13 output push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init( GPIOD, &GPIO_InitStructure );
// Enable timer clocks
RCC_APB1PeriphClockCmd( RCC_APB1Periph_TIM2, ENABLE );
TIM_TimeBaseStructInit( &TIM_TimeBaseStructure );
// Time base configuration for timer 2 - which generates the interrupts.
n = (configCPU_CLOCK_HZ / params->toggleFrequency);
TIM_TimeBaseStructure.TIM_Period = 65535;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit( TIM2, &TIM_TimeBaseStructure );
TIM_ARRPreloadConfig( TIM2, ENABLE );
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 13;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init( &NVIC_InitStructure );
return 0;
TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
TIM_Cmd(TIM2, ENABLE);
for (;
if ( xSemaphoreTake(xSemaphore0, portMAX_DELAY) == pdTRUE ) {
GPIO_WriteBit( GPIOD, GPIO_Pin_13, Bit_SET);
unsigned long ulLine = Line3;
const unsigned long ulLineHeight = 24;
static char cMsgBuf;
LcdMsg msg;
/* The LCD gatekeeper task as described in the comments at the top of this
file. */
//Initialize the LCD.
STM3210C_LCD_Init();
// Display a startup message.
LCD_Clear(White);
LCD_SetTextColor(Green);
LCD_DisplayStringLine( Line0, ( unsigned char * ) " www.FreeRTOS.org" );
LCD_SetTextColor(Blue);
LCD_DisplayStringLine( Line1, ( unsigned char * ) " Project 4 example" );
LCD_SetTextColor(Black);
for( ;; )
/* Wait for a message to arrive to be displayed. */
xQueueReceive( g_lcdQueue, &msg, portMAX_DELAY );
/* Clear the current line of text. */
LCD_ClearLine( ulLine );
/* Move on to the next line. */
ulLine += ulLineHeight;
if( ulLine > Line9 )
ulLine = Line3;
//Display the received text
LCD_DisplayStringLine( ulLine, ( unsigned char * )msg.msg );
