Stack Water Mark - Performnance
slicetex wrote on Wednesday, March 16, 2011:
I’m using freertos with INCLUDE_uxTaskGetStackHighWaterMark feature enabled.
This feature affects the RTOS performance (speed) significantly ?.
Thanks
Boris Estudiez.-
davedoors wrote on Wednesday, March 16, 2011:
The INCLUDE_uxTaskGetStackHighWaterMark setting should not make any difference to the performance. It will increase the code size a little bit if the function is actually called, that is all.
