Speed up FreeRTOS+TCP on Zynq
@tony-josi-aws
Thanks for putting in the time and effort!
I adapted my config with your values and did the measurements with the same commands as you. Also I changed from our own carrier board to the Trenz TE0701 to rule out any hardware problems with our carrier.
I am also measuring >900 Mbit/s in UDP but again only ~50 Mbit/s with TCP.
But from my experience I don’t think your UDP measurement shows the whole truth; with iperf when measuring UDP one has to always take the loss rate into account, the bandwidth that is shown is the sender bandwidth, not necessary the real bandwidth. This can be mittigated by using iperf2 or using the reverse option on iperf3, but that unfortunately doesn’t work with the given iperf implementation.
Also given that the TCP bandwidth is around 300-350 Mbits/s, the UDP bandwith is much more likely to be in the 400-500Mbit/s range.
That being said, if your UDP rate of 900 and your TCP rate of 300-350 (which gives around 60% of TCP overhead) are actually correct, I should observe a similar TCP overhead and thus also around 300-350 Mbit/s TCP rate. So again, I don’t think the UDP rate we are both measuring with this method is correct.
Can you think of a possibility to improve this test?
This is the FreeRTOSIPConfig.h that I used, maybe you can take a look and check if you can update anything:
 * FreeRTOS Kernel V10.2.0
 * Copyright (C) 2018 Amazon.com, Inc. or its affiliates.  All Rights Reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a copy of
 * this software and associated documentation files (the "Software"), to deal in
 * the Software without restriction, including without limitation the rights to
 * use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
 * the Software, and to permit persons to whom the Software is furnished to do so,
 * subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in all
 * copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
 * FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
 * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
 * IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
 * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
 * http://aws.amazon.com/freertos
 * http://www.FreeRTOS.org
* See the following URL for configuration information.
* http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_TCP/TCP_IP_Configuration.html
#ifndef FREERTOS_IP_CONFIG_H
#define FREERTOS_IP_CONFIG_H
#define ipconfigMULTI_INTERFACE 1
#define ipconfigSUPPORT_SIGNALS 1
#define BUILD_IPERF3			1
#if BUILD_IPERF3
#define ipconfigIPERF_PRIORITY_IPERF_TASK               6
#define ipconfigIPERF_DOES_ECHO_UDP                     1
#define ipconfigIPERF_VERSION                           3
#define ipconfigIPERF_STACK_SIZE_IPERF_TASK             680
#define ipconfigIPERF_TX_BUFSIZE                        ( 48 * ipconfigTCP_MSS )
#define ipconfigIPERF_TX_WINSIZE                        ( 48 )
#define ipconfigIPERF_RX_BUFSIZE                        ( 48 * ipconfigTCP_MSS )
#define ipconfigIPERF_RX_WINSIZE                        ( 48 )
/* The iperf module declares a character buffer to store its send data. */
#define ipconfigIPERF_RECV_BUFFER_SIZE                  ( 48 * ipconfigTCP_MSS )
/* Prototype for the function used to print out.  In this case it prints to the
 * console before the network is connected then a UDP port after the network has
 * connected. */
extern void vLoggingPrintf( const char * pcFormatString,
/* Set to 1 to print out debug messages.  If ipconfigHAS_DEBUG_PRINTF is set to
 * 1 then FreeRTOS_debug_printf should be defined to the function used to print
 * out the debugging messages. */
#define ipconfigHAS_DEBUG_PRINTF    0
#if ( ipconfigHAS_DEBUG_PRINTF == 1 )
    #define FreeRTOS_debug_printf( X )    configPRINTF( X )
/* Set to 1 to print out non debugging messages, for example the output of the
 * FreeRTOS_netstat() command, and ping replies.  If ipconfigHAS_PRINTF is set to 1
 * then FreeRTOS_printf should be set to the function used to print out the
 * messages. */
#define ipconfigHAS_PRINTF    0
#if ( ipconfigHAS_PRINTF == 1 )
    #define FreeRTOS_printf( X )    configPRINTF( X )
/* Define the byte order of the target MCU (the MCU FreeRTOS+TCP is executing
 * on).  Valid options are pdFREERTOS_BIG_ENDIAN and pdFREERTOS_LITTLE_ENDIAN. */
#define ipconfigBYTE_ORDER                         pdFREERTOS_LITTLE_ENDIAN
/* If the network card/driver includes checksum offloading (IP/TCP/UDP checksums)
 * then set ipconfigDRIVER_INCLUDED_RX_IP_CHECKSUM to 1 to prevent the software
 * stack repeating the checksum calculations. */
#define ipconfigDRIVER_INCLUDED_TX_IP_CHECKSUM		( 0 )
#define ipconfigDRIVER_INCLUDED_RX_IP_CHECKSUM		( 1 )
#define ipconfigZERO_COPY_RX_DRIVER					( 1 )
#define ipconfigZERO_COPY_TX_DRIVER					( 1 )
/* Several API's will block until the result is known, or the action has been
 * performed, for example FreeRTOS_send() and FreeRTOS_recv().  The timeouts can be
 * set per socket, using setsockopt().  If not set, the times below will be
 * used as defaults. */
#define ipconfigSOCK_DEFAULT_RECEIVE_BLOCK_TIME    ( 10000 )
#define ipconfigSOCK_DEFAULT_SEND_BLOCK_TIME       ( 10000 )
/* Include support for LLMNR: Link-local Multicast Name Resolution
 * (non-Microsoft) */
#define ipconfigUSE_LLMNR                          ( 1 )
/* Include support for NBNS: NetBIOS Name Service (Microsoft) */
#define ipconfigUSE_NBNS                           ( 1 )
/* Include support for DNS caching.  For TCP, having a small DNS cache is very
 * useful.  When a cache is present, ipconfigDNS_REQUEST_ATTEMPTS can be kept low
 * and also DNS may use small timeouts.  If a DNS reply comes in after the DNS
 * socket has been destroyed, the result will be stored into the cache.  The next
 * call to FreeRTOS_gethostbyname() will return immediately, without even creating
 * a socket.
#define ipconfigUSE_DNS_CACHE                      ( 1 )
#define ipconfigDNS_CACHE_ADDRESSES_PER_ENTRY      ( 6 )
#define ipconfigDNS_CACHE_NAME_LENGTH              ( 254 )
#define ipconfigDNS_CACHE_ENTRIES                  ( 4 )
#define ipconfigDNS_REQUEST_ATTEMPTS               ( 2 )
/* The IP stack executes it its own task (although any application task can make
 * use of its services through the published sockets API). ipconfigUDP_TASK_PRIORITY
 * sets the priority of the task that executes the IP stack.  The priority is a
 * standard FreeRTOS task priority so can take any value from 0 (the lowest
 * priority) to (configMAX_PRIORITIES - 1) (the highest priority).
 * configMAX_PRIORITIES is a standard FreeRTOS configuration parameter defined in
 * FreeRTOSConfig.h, not FreeRTOSIPConfig.h. Consideration needs to be given as to
 * the priority assigned to the task executing the IP stack relative to the
 * priority assigned to tasks that use the IP stack. */
#define ipconfigIP_TASK_PRIORITY                   ( configMAX_PRIORITIES - 2 )
/* The size, in words (not bytes), of the stack allocated to the FreeRTOS+TCP
 * task.  This setting is less important when the FreeRTOS Win32 simulator is used
 * as the Win32 simulator only stores a fixed amount of information on the task
 * stack.  FreeRTOS includes optional stack overflow detection, see:
 * http://www.freertos.org/Stacks-and-stack-overflow-checking.html. */
#define ipconfigIP_TASK_STACK_SIZE_WORDS           ( configMINIMAL_STACK_SIZE * 5 )
/* ipconfigRAND32() is called by the IP stack to generate random numbers for
 * things such as a DHCP transaction number or initial sequence number.  Random
 * number generation is performed via this macro to allow applications to use their
 * own random number generation method.  For example, it might be possible to
 * generate a random number by sampling noise on an analogue input. */
// extern uint32_t uxRand();
// #define ipconfigRAND32()    uxRand()
/* If ipconfigUSE_NETWORK_EVENT_HOOK is set to 1 then FreeRTOS+TCP will call the
 * network event hook at the appropriate times.  If ipconfigUSE_NETWORK_EVENT_HOOK
 * is not set to 1 then the network event hook will never be called. See:
 * http://www.FreeRTOS.org/FreeRTOS-Plus/FreeRTOS_Plus_UDP/API/vApplicationIPNetworkEventHook.shtml.
#define ipconfigUSE_NETWORK_EVENT_HOOK           1
/* Sockets have a send block time attribute.  If FreeRTOS_sendto() is called but
 * a network buffer cannot be obtained then the calling task is held in the Blocked
 * state (so other tasks can continue to executed) until either a network buffer
 * becomes available or the send block time expires.  If the send block time expires
 * then the send operation is aborted.  The maximum allowable send block time is
 * capped to the value set by ipconfigMAX_SEND_BLOCK_TIME_TICKS.  Capping the
 * maximum allowable send block time prevents prevents a deadlock occurring when
 * all the network buffers are in use and the tasks that process (and subsequently
 * free) the network buffers are themselves blocked waiting for a network buffer.
 * ipconfigMAX_SEND_BLOCK_TIME_TICKS is specified in RTOS ticks.  A time in
 * milliseconds can be converted to a time in ticks by dividing the time in
 * milliseconds by portTICK_PERIOD_MS. */
#define ipconfigUDP_MAX_SEND_BLOCK_TIME_TICKS    ( 20000 / portTICK_PERIOD_MS )
/* If ipconfigUSE_DHCP is 1 then FreeRTOS+TCP will attempt to retrieve an IP
 * address, netmask, DNS server address and gateway address from a DHCP server.  If
 * ipconfigUSE_DHCP is 0 then FreeRTOS+TCP will use a static IP address.  The
 * stack will revert to using the static IP address even when ipconfigUSE_DHCP is
 * set to 1 if a valid configuration cannot be obtained from a DHCP server for any
 * reason.  The static configuration used is that passed into the stack by the
 * FreeRTOS_IPInit() function call. */
#define ipconfigUSE_DHCP                         1
#define ipconfigDHCP_REGISTER_HOSTNAME           1
#define ipconfigDHCP_USES_UNICAST                1
/* If ipconfigDHCP_USES_USER_HOOK is set to 1 then the application writer must
 * provide an implementation of the DHCP callback function,
 * xApplicationDHCPUserHook(). */
#define ipconfigUSE_DHCP_HOOK                    0
/* When ipconfigUSE_DHCP is set to 1, DHCP requests will be sent out at
 * increasing time intervals until either a reply is received from a DHCP server
 * and accepted, or the interval between transmissions reaches
 * ipconfigMAXIMUM_DISCOVER_TX_PERIOD.  The IP stack will revert to using the
 * static IP address passed as a parameter to FreeRTOS_IPInit() if the
 * re-transmission time interval reaches ipconfigMAXIMUM_DISCOVER_TX_PERIOD without
 * a DHCP reply being received. */
#define ipconfigMAXIMUM_DISCOVER_TX_PERIOD \
    ( 120000 / portTICK_PERIOD_MS )
/* The ARP cache is a table that maps IP addresses to MAC addresses.  The IP
 * stack can only send a UDP message to a remove IP address if it knowns the MAC
 * address associated with the IP address, or the MAC address of the router used to
 * contact the remote IP address.  When a UDP message is received from a remote IP
 * address the MAC address and IP address are added to the ARP cache.  When a UDP
 * message is sent to a remote IP address that does not already appear in the ARP
 * cache then the UDP message is replaced by a ARP message that solicits the
 * required MAC address information.  ipconfigARP_CACHE_ENTRIES defines the maximum
 * number of entries that can exist in the ARP table at any one time. */
#define ipconfigARP_CACHE_ENTRIES                 6
/* ARP requests that do not result in an ARP response will be re-transmitted a
 * maximum of ipconfigMAX_ARP_RETRANSMISSIONS times before the ARP request is
 * aborted. */
#define ipconfigMAX_ARP_RETRANSMISSIONS           ( 5 )
/* ipconfigMAX_ARP_AGE defines the maximum time between an entry in the ARP
 * table being created or refreshed and the entry being removed because it is stale.
 * New ARP requests are sent for ARP cache entries that are nearing their maximum
 * age.  ipconfigMAX_ARP_AGE is specified in tens of seconds, so a value of 150 is
 * equal to 1500 seconds (or 25 minutes). */
#define ipconfigMAX_ARP_AGE                       150
/* Implementing FreeRTOS_inet_addr() necessitates the use of string handling
 * routines, which are relatively large.  To save code space the full
 * FreeRTOS_inet_addr() implementation is made optional, and a smaller and faster
 * alternative called FreeRTOS_inet_addr_quick() is provided.  FreeRTOS_inet_addr()
 * takes an IP in decimal dot format (for example, "192.168.0.1") as its parameter.
 * FreeRTOS_inet_addr_quick() takes an IP address as four separate numerical octets
 * (for example, 192, 168, 0, 1) as its parameters.  If
 * ipconfigINCLUDE_FULL_INET_ADDR is set to 1 then both FreeRTOS_inet_addr() and
 * FreeRTOS_indet_addr_quick() are available.  If ipconfigINCLUDE_FULL_INET_ADDR is
 * not set to 1 then only FreeRTOS_indet_addr_quick() is available. */
#define ipconfigINCLUDE_FULL_INET_ADDR            1
/* ipconfigNUM_NETWORK_BUFFER_DESCRIPTORS defines the total number of network buffer that
 * are available to the IP stack.  The total number of network buffers is limited
 * to ensure the total amount of RAM that can be consumed by the IP stack is capped
 * to a pre-determinable value. */
#define ipconfigNUM_NETWORK_BUFFER_DESCRIPTORS    96U
#define ipconfigUSE_LINKED_RX_MESSAGES	1
/* A FreeRTOS queue is used to send events from application tasks to the IP
 * stack.  ipconfigEVENT_QUEUE_LENGTH sets the maximum number of events that can
 * be queued for processing at any one time.  The event queue must be a minimum of
 * 5 greater than the total number of network buffers. */
#define ipconfigEVENT_QUEUE_LENGTH \
    ( ipconfigNUM_NETWORK_BUFFER_DESCRIPTORS + 5 )
/* The address of a socket is the combination of its IP address and its port
 * number.  FreeRTOS_bind() is used to manually allocate a port number to a socket
 * (to 'bind' the socket to a port), but manual binding is not normally necessary
 * for client sockets (those sockets that initiate outgoing connections rather than
 * wait for incoming connections on a known port number).  If
 * ipconfigALLOW_SOCKET_SEND_WITHOUT_BIND is set to 1 then calling
 * FreeRTOS_sendto() on a socket that has not yet been bound will result in the IP
 * stack automatically binding the socket to a port number from the range
 * socketAUTO_PORT_ALLOCATION_START_NUMBER to 0xffff.  If
 * ipconfigALLOW_SOCKET_SEND_WITHOUT_BIND is set to 0 then calling FreeRTOS_sendto()
 * on a socket that has not yet been bound will result in the send operation being
 * aborted. */
#define ipconfigALLOW_SOCKET_SEND_WITHOUT_BIND         1
/* Defines the Time To Live (TTL) values used in outgoing UDP packets. */
#define ipconfigUDP_TIME_TO_LIVE                       128
/* Also defined in FreeRTOSIPConfigDefaults.h. */
#define ipconfigTCP_TIME_TO_LIVE                       128
/* USE_TCP: Use TCP and all its features. */
#define ipconfigUSE_TCP                                ( 1 )
/* USE_WIN: Let TCP use windowing mechanism. */
#define ipconfigUSE_TCP_WIN                            ( 1 )
/* The MTU is the maximum number of bytes the payload of a network frame can
 * contain.  For normal Ethernet V2 frames the maximum MTU is 1500.  Setting a
 * lower value can save RAM, depending on the buffer management scheme used.  If
 * ipconfigCAN_FRAGMENT_OUTGOING_PACKETS is 1 then (ipconfigNETWORK_MTU - 28) must
 * be divisible by 8. */
#define ipconfigNETWORK_MTU                            1500U
/* Set ipconfigUSE_DNS to 1 to include a basic DNS client/resolver.  DNS is used
 * through the FreeRTOS_gethostbyname() API function. */
#define ipconfigUSE_DNS                                1
/* If ipconfigREPLY_TO_INCOMING_PINGS is set to 1 then the IP stack will
 * generate replies to incoming ICMP echo (ping) requests. */
#define ipconfigREPLY_TO_INCOMING_PINGS                1
/* If ipconfigSUPPORT_OUTGOING_PINGS is set to 1 then the
 * FreeRTOS_SendPingRequest() API function is available. */
#define ipconfigSUPPORT_OUTGOING_PINGS                 1
/* If ipconfigSUPPORT_SELECT_FUNCTION is set to 1 then the FreeRTOS_select()
 * (and associated) API function is available. */
#define ipconfigSUPPORT_SELECT_FUNCTION                1
/* If ipconfigFILTER_OUT_NON_ETHERNET_II_FRAMES is set to 1 then Ethernet frames
 * that are not in Ethernet II format will be dropped.  This option is included for
 * potential future IP stack developments. */
#define ipconfigFILTER_OUT_NON_ETHERNET_II_FRAMES      1
/* If ipconfigETHERNET_DRIVER_FILTERS_FRAME_TYPES is set to 1 then it is the
 * responsibility of the Ethernet interface to filter out packets that are of no
 * interest.  If the Ethernet interface does not implement this functionality, then
 * set ipconfigETHERNET_DRIVER_FILTERS_FRAME_TYPES to 0 to have the IP stack
 * perform the filtering instead (it is much less efficient for the stack to do it
 * because the packet will already have been passed into the stack).  If the
 * Ethernet driver does all the necessary filtering in hardware then software
 * filtering can be removed by using a value other than 1 or 0. */
#define ipconfigETHERNET_DRIVER_FILTERS_FRAME_TYPES    1
/* The windows simulator cannot really simulate MAC interrupts, and needs to
 * block occasionally to allow other tasks to run. */
#define configWINDOWS_MAC_INTERRUPT_SIMULATOR_DELAY    ( 20 / portTICK_PERIOD_MS )
/* Advanced only: in order to access 32-bit fields in the IP packets with
 * 32-bit memory instructions, all packets will be stored 32-bit-aligned,
 * plus 16-bits. This has to do with the contents of the IP-packets: all
 * 32-bit fields are 32-bit-aligned, plus 16-bit. */
#define ipconfigPACKET_FILLER_SIZE                     2U
/* Define the size of the pool of TCP window descriptors.  On the average, each
 * TCP socket will use up to 2 x 6 descriptors, meaning that it can have 2 x 6
 * outstanding packets (for Rx and Tx).  When using up to 10 TP sockets
 * simultaneously, one could define TCP_WIN_SEG_COUNT as 120. */
#define ipconfigTCP_WIN_SEG_COUNT                      240
/* Each TCP socket has a circular buffers for Rx and Tx, which have a fixed
 * maximum size.  Define the size of Rx buffer for TCP sockets. */
#define ipconfigTCP_RX_BUFFER_LENGTH                   ( 0x4000 )
/* Define the size of Tx buffer for TCP sockets. */
#define ipconfigTCP_TX_BUFFER_LENGTH                   ( 0x4000 )
/* When using call-back handlers, the driver may check if the handler points to
 * real program memory (RAM or flash) or just has a random non-zero value. */
#define ipconfigIS_VALID_PROG_ADDRESS( x )    ( ( x ) != NULL )
/* Include support for TCP hang protection.  All sockets in a connecting or
 * disconnecting stage will timeout after a period of non-activity. */
//#define ipconfigTCP_HANG_PROTECTION              ( 1 )
//#define ipconfigTCP_HANG_PROTECTION_TIME         ( 30 )
/* Include support for TCP keep-alive messages. */
#define ipconfigTCP_KEEP_ALIVE                   ( 1 )
#define ipconfigTCP_KEEP_ALIVE_INTERVAL          ( 20 ) /* Seconds. */
 /* Zynq driver specific parameters */
 #define ipconfigNIC_INCLUDE_GEM				( 1 )
 #define ipconfigNIC_N_TX_DESC				( 32 )
 #define ipconfigNIC_N_RX_DESC				( 32 )
 //#define ipconfigNIC_LINKSPEED100			( 1 )
 #define ipconfigNIC_LINKSPEED_AUTODETECT	(1)
 /* When set to 1, the application writer must provide the implementation of a
 function with the following name and prototype:
 BaseType_t xApplicationDNSQueryHook( const char *pcName );
 The function must return pdTRUE if pcName matches a test name assigned to the
 device, and pdFALSE in all other cases.  */
 #define ipconfigDNS_USE_CALLBACKS			1
/* The socket semaphore is used to unblock the MQTT task. */
#define ipconfigSOCKET_HAS_USER_SEMAPHORE        ( 0 )
#define ipconfigSOCKET_HAS_USER_WAKE_CALLBACK    ( 1 )
#define ipconfigUSE_CALLBACKS                    ( 0 )
#define portINLINE                               __inline
#endif /* FREERTOS_IP_CONFIG_H */
Also make sure to disable compiler debug flags and enable optimization (used O2).
Other than that the type of ethernet cable, congestion in the router/network can also impact the speed, try switching the cable, use direct connection to PC, etc.
Thanks @tony-josi-aws !
Is I have mentioned earlier, I am already using O3 and no debug flags and am connected directly to the PC and using a cable that I verified can carry >950Mbit/s UDP and >700Mbit/s TCP.
Could you tell me what hardware you are testing this on?
I have finally verified, that with -O3, no debug flags and the IPConfig you shared I can also measure around 350Mbits/sec with iperf3 TCP.
However, with iperf3 UDP I also get >900Mbits/sec and not a single lost packet, with seems highly anrealistic to me, as I have explained above.
I’d like to test it in reverse with the -R flag, but the iperf implementation doesn’t seem to support this.
Can anyone verify that?
This IPERF implementation by @htibosch : freertos_plus_projects/plus/Common/Utilities/iperf_task_v3_0f.c at master · htibosch/freertos_plus_projects · GitHub
seems to support the reverse (-R) option. I haven’t tested this with -R option.
Would like to know how it goes.
That’s the implementation I tested with and the rate is always 0 with the -R option.
Can @htibosch maybe comment on this?
