Should prvWriteNameToBuffer() be enabled under static allocation?
In tasks.c, is declared and defined with the following compile-time conditionals:
#if ((configUSE_TRACE_FACILITY == 1) && (configUSE_STATS_FORMATTING_FUNCTIONS > 0))
static char *prvWriteNameToBuffer(char *pcBuffer, const char *pcTaskName) PRIVILEGED_FUNCTION;
… but it is CALLED with the following compile-time switches:
#if ((configUSE_TRACE_FACILITY == 1) && (configUSE_STATS_FORMATTING_FUNCTIONS > 0)                                     \
     && (configSUPPORT_DYNAMIC_ALLOCATION == 1))
void vTaskList(char *pcWriteBuffer) {
  pcWriteBuffer = prvWriteNameToBuffer(pcWriteBuffer, pxTaskStatusArray[x].pcTaskName);
This means you’ll get a compile time warning:
Severity	Code	Description	Project	File	Line
Error		'prvWriteNameToBuffer' defined but not used [-Werror=unused-function]	...FreeRTOSV10.0.0\Source\tasks.c	3791
Consequently, if you run with warnings == errors, your compile will fail if configSUPPORT_DYNAMIC_ALLOCATION == 0.
Seems like a bug. Or am I confused?
There are a couple of functions that call prvWriteNameToBuffer(), one requires the following config file settings:
#if ( ( configUSE_TRACE_FACILITY == 1 ) && ( configUSE_STATS_FORMATTING_FUNCTIONS > 0 ) && ( configSUPPORT_DYNAMIC_ALLOCATION == 1 ) )
…and the other
#if ( ( configGENERATE_RUN_TIME_STATS == 1 ) && ( configUSE_STATS_FORMATTING_FUNCTIONS > 0 ) && ( configSUPPORT_DYNAMIC_ALLOCATION == 1 ) )
So it does indeed look like prvWriteNameToBuffer() is only used when configSUPPORT_DYNAMIC_ALLOCATION is 1.
Grateful if you could create a PR to change this.
Gladly. One question: the github FreeRTOS top level shows sources at branch a4b2ae3:
https://github.com/FreeRTOS/FreeRTOS-Kernel/tree/a4b28e35103d699edf074dfff4835921b481b301
Should I base the PR on that, or from the main branch:
https://github.com/FreeRTOS/FreeRTOS-Kernel/tree/main
(or does it matter)? Thanks…
Hmm. Should be at the tip of main.
That makes sense – I’ll use main.
