Does anyone have experience with freertos working with a AT91SAM7SE (512)? I’m about starting a project on one and the hardware hasnt arrived yet. The SAM7SE is almost identical to the SAM7S but sometimes it takes just a small change.
As far as I know (from my brief investigation) you should find the only difference is the external memory interface, which will need setting up. I have not actually tried it myself however, so cannot be completely sure.
I heard something of a simplified booting method or something…as I said…sometimes its the small things and if it doesnt run at all there is no use in trying for weeks…cause I dont have much time right now…
