You are connecting STM32 device to the PC and the STM32 device makes an Ethernet port available to the PC. The PC assigns an IP address (169.254.107.173
) to this port. Now, when you send any data using this port, it will reach the STM32 device. Is the STM32 device connected to LAN/internet? In other words, if you disconnect every other network connection from the PC (WiFi or Ethernet), are you able to access internet?
Next, you are running a network stack (FreeRTOS-Plus-TCP) on the STM32 device. Are you able to reach the internet from the STM32 device? What IP is getting assigned to the STM32 device?
Once, the above 2 things are confirmed, we should look into who is starting the web server and if is accessible from a device on the same network.
