I’m wondering if/when the Renesas RX71M will be supported. On the
Renesas Homepage FreeRTOS is listed
(http://www.renesas.com/press/news/2015/news20150127.jsp) however on
the FreeRTOS Ports listings, the RX71M is not listed. Is the Port
compatible with the RX64M V2 core?
We have not run FreeRTOS on the RX71M, but are not aware of any reason why FreeRTOS’s existing RXv2 port (demonstrated on the RX64M) would not also work correctly on the RX71M.
Care must be taken to ensure the RX71M’s MEMWAIT register is set before the clock speed is increased, but that is outside the scope of the RTOS.
