Hi.
I’m using FreeRtos with GNURX (RX62N) in HEW.
In hardware manual i see that after S12AD interrupt, exist various address reserved ( from 0x019C to 0x01C4). When i see your code in RelocatableVectors in vects.c show this:
this means that TGIOA interrut is in adress 0x01A0?? this adress should be reserved according to hardware manual because this interrupt should be in 0x01C8.
It is not my code. If you look at the top of the file you will see:
/* FILE :vects.c */
/* DATE :Wed, Aug 25, 2010 */
/* DESCRIPTION :Vector Table */
/* CPU TYPE :Other */
/* This file is generated by KPIT GNU Project Generator. */
Looking at the file, I see something completely different, as shown below:
The problem is not here. the problem is that from vector adress 0x019C to 0x01C4 should be reserved because in hardware manual is reserved. In this code generate with KPIT GNU generator this adrees are filled with other interrupts that no correspond with this vector adress.
