Regarding DHCP Functionality, IP Address is not allocated
Hello Aniruddha,
Thanks for replying. I have gone through the path that code follows. DHCP hook is enabled and xApplicationDHCPHook is returning the eReturn = eDHCPContinue; .
xApplicationDHCPHook is called from case : eWaitingSendFirstDiscover
and case : eWaitingOffer inside vDHCPProcessEndPoint() function
  1. When xApplicationDHCPHook is called from case : eWaitingSendFirstDiscover it returns eReturn = eDHCPContinue
case eWaitingSendFirstDiscover :
        /* Ask the user if a DHCP discovery is required. */
    #if( ipconfigUSE_DHCP_HOOK != 0 )
        **eAnswer = xApplicationDHCPHook( eDHCPPhasePreDiscover, pxEndPoint->ulDefaultIPAddress );**
        if( eAnswer == eDHCPContinue )
    #endif  /* ipconfigUSE_DHCP_HOOK */
            /* Initial state.  Create the DHCP socket, timer, etc. if they
            have not already been created. */
            prvInitialiseDHCP( pxEndPoint );
            /* Put 'ulIPAddress' to zero to indicate that the end-point is down. */
            pxEndPoint->ulIPAddress = 0UL;
            /* Send the first discover request. */
            if( xDHCPSocket != NULL )
                pxEndPoint->xDHCPData.xDHCPTxTime = xTaskGetTickCount();
                prvSendDHCPDiscover( pxEndPoint );
                pxEndPoint->xDHCPData.eDHCPState = eWaitingOffer;
        else
            if( eAnswer == eDHCPUseDefaults )
                memcpy( &xNetworkAddressing, &xDefaultAddressing, sizeof( xNetworkAddressing ) );
            /* The user indicates that the DHCP process does not continue. */
            xGivingUp = pdTRUE;
        break;
  1. After that it changes its state from eWaitingSendFirstDiscover to eWaitingOffer and now after it goes in case : eWaitingOffer the following if condition is not executed. Due to which the xApplicationDHCPHook is not called again as it stucks there and execute the else if part mentioned below.
if( ( xDoCheck != pdFALSE ) && ( prvProcessDHCPReplies( dhcpMESSAGE_TYPE_OFFER, pxEndPoint ) == pdPASS ) )
case eWaitingOffer :
        xGivingUp = pdFALSE;
        /* Look for offers coming in. */
            /* Ask the user if a DHCP request is required. */
            eAnswer = xApplicationDHCPHook( eDHCPPhasePreRequest, pxEndPoint->xDHCPData.ulOfferedIPAddress );
                /* An offer has been made, the user wants to continue,
                generate the request. */
                pxEndPoint->xDHCPData.xDHCPTxPeriod = dhcpINITIAL_DHCP_TX_PERIOD;
                prvSendDHCPRequest( pxEndPoint );
                pxEndPoint->xDHCPData.eDHCPState = eWaitingAcknowledge;
                break;
                pxEndPoint->ulIPAddress = pxEndPoint->ulDefaultIPAddress;   /* Use this address in case DHCP has failed. */
            xGivingUp = pdTRUE;
        /* Is it time to send another Discover? */
        **else if( ( xTaskGetTickCount() - pxEndPoint->xDHCPData.xDHCPTxTime ) > pxEndPoint->xDHCPData.xDHCPTxPeriod )**
            /* Increase the time period, and if it has not got to the
            point of giving up - send another discovery. */
            pxEndPoint->xDHCPData.xDHCPTxPeriod <<= 1;
            if( pxEndPoint->xDHCPData.xDHCPTxPeriod <= ipconfigMAXIMUM_DISCOVER_TX_PERIOD )
                pxEndPoint->xDHCPData.ulTransactionId++;
                pxEndPoint->xDHCPData.xUseBroadcast = !pxEndPoint->xDHCPData.xUseBroadcast;
                FreeRTOS_printf( ( "vDHCPProcess[%02x-%02x]: timeout %lu ticks\n",
                    pxEndPoint->xMACAddress.ucBytes[ 4 ],
                    pxEndPoint->xMACAddress.ucBytes[ 5 ],
                    pxEndPoint->xDHCPData.xDHCPTxPeriod ) );
            else
                FreeRTOS_printf( ( "vDHCPProcess[%02x-%02x]: giving up %lu > %lu ticks\n",
                    pxEndPoint->xDHCPData.xDHCPTxPeriod, ipconfigMAXIMUM_DISCOVER_TX_PERIOD ) );
                #if( ipconfigDHCP_FALL_BACK_AUTO_IP != 0 )
                    /* Only use a fake Ack if the default IP address == 0x00
                    and the link local addressing is used.  Start searching
                    a free LinkLayer IP-address.  Next state will be
                    'eGetLinkLayerAddress'. */
                    prvPrepareLinkLayerIPLookUp();
                    /* Setting an IP address manually so set to not using
                    leased address mode. */
                    pxEndPoint->xDHCPData.eDHCPState = eGetLinkLayerAddress;
                #else
                    xGivingUp = pdTRUE;
                #endif /* ipconfigDHCP_FALL_BACK_AUTO_IP */
        break;
  1. Now I have observed that in vDHCPProcess() function the lBytes is calculated from FreeRTOS_recvfrom() function and then the condition ( lBytes <= 0 ) is checked. Here the value of lBytes is always -11 i.e
    pdFREERTOS_ERRNO_EWOULDBLOCK
    . So it never complete the for loop and break from the condition ( lBytes <= 0 ).
void vDHCPProcess( BaseType_t xReset, NetworkEndPoint_t *pxEndPoint )
    /* If there is a socket, check for incoming messasges first. */
    uint8_t *pucUDPPayload;
    DHCPMessage_IPv4_t *pxDHCPMessage;
    BaseType_t lBytes;
        for( ;; )
        NetworkEndPoint_t *pxIterator = NULL;
            /* Peek the next UDP message. */
            lBytes = FreeRTOS_recvfrom( xDHCPSocket, ( void * ) &pucUDPPayload, 0, FREERTOS_ZERO_COPY | FREERTOS_MSG_PEEK, NULL, NULL );
            if( lBytes <= 0 )
                if( ( lBytes < 0 ) && ( lBytes != -pdFREERTOS_ERRNO_EAGAIN ) )
                    FreeRTOS_printf( ( "vDHCPProcess: FreeRTOS_recvfrom returns %d\n", lBytes ) );
                break;
            /* Map a DHCP structure onto the received data. */
            pxDHCPMessage = ( DHCPMessage_IPv4_t * ) ( pucUDPPayload );
            /* Sanity check. */
            if( ( pxDHCPMessage->ulDHCPCookie == dhcpCOOKIE ) && ( pxDHCPMessage->ucOpcode == dhcpREPLY_OPCODE ) )
                pxIterator = pxNetworkEndPoints;
                /* Find the end-point with given transaction ID. */
                while( pxIterator != NULL )
                    if( pxDHCPMessage->ulTransactionID == FreeRTOS_htonl( pxIterator->xDHCPData.ulTransactionId ) )
                        break;
                    pxIterator = pxIterator->pxNext;
            if( ( pxIterator != NULL ) && ( pxIterator->xDHCPData.eDHCPState == eLeasedAddress ) )
                pxIterator = NULL;
            if( pxIterator != NULL )
                #if( ipconfigHAS_DEBUG_PRINTF != 0 )
                    FreeRTOS_debug_printf( ( "vDHCPProcess[%02x-%02x] ID %04X: state %s found xReset %d\n",
                        pxIterator->xMACAddress.ucBytes[ 4 ],
                        pxIterator->xMACAddress.ucBytes[ 5 ],
                        pxIterator->xDHCPData.ulTransactionId,
                        pcDHCPStateName( pxIterator->xDHCPData.eDHCPState ) ) );
                #endif /* ipconfigHAS_DEBUG_PRINTF */
                /* The second parameter pdTRUE tells to check for a UDP message. */
                vDHCPProcessEndPoint( pdFALSE, pdTRUE, pxIterator );
                if( pxEndPoint == pxIterator )
                    pxEndPoint = NULL;
            else
                /* Target not found, fetch the message and delete it. */
                lBytes = FreeRTOS_recvfrom( xDHCPSocket, ( void * ) &pucUDPPayload, 0, FREERTOS_ZERO_COPY, NULL, NULL );
                if( lBytes > 0 )
                    /* Remove it now, destination not found. */
                    FreeRTOS_ReleaseUDPPayloadBuffer( ( void * ) pucUDPPayload );
                    FreeRTOS_printf( ( "vDHCPProcess: Removed a %d-byte message: target not found\n", lBytes ) );
    if( pxEndPoint != NULL )
        vDHCPProcessEndPoint( xReset, pdFALSE, pxEndPoint );
I will also debug further and will let you know the observation.
Thanks
Prince Tripathi
