Receive muliple packages
boble wrote on Tuesday, December 12, 2017:
I’m using a SAM4E EK with the GMAC example from the atmel asf.
I’m running into some problems with receiving multiple packages.
I can receive a request and then send the website in multiple packages but can’t receive multiple packages.
I hope that you guys can help me because I can’t think of anything else.
for( ;; )
		#if ( (LWIP_VERSION) == ((1U << 24) | (3U << 16) | (2U << 8) | (LWIP_VERSION_RC)) )
		/* Wait for a first connection. */
		pxNewConnection = netconn_accept(pxHTTPListener);
		#else
		while(netconn_accept(pxHTTPListener, &pxNewConnection) != ERR_OK)
			vTaskDelay( webSHORT_DELAY );
		vParTestSetLED(webCONN_LED, pdTRUE);
		if(pxNewConnection != NULL)
			prvweb_ParseHTMLRequest(pxNewConnection);
			}/* end if new connection */
			vParTestSetLED(webCONN_LED, pdFALSE);
			} /* end infinite loop */
		/*! \brief parse the incoming request
		*         parse the HTML request and send file
		*  \param pxNetCon   Input. The netconn to use to send and receive data.
		static void prvweb_ParseHTMLRequest( struct netconn *pxNetCon )
			struct netbuf *pxRxBuffer;
			portCHAR *pcRxString;
			unsigned portSHORT usLength;
			/* We expect to immediately get data. */
			pxRxBuffer = netconn_recv( pxNetCon );
			#else
			while(netconn_recv( pxNetCon, &pxRxBuffer) != ERR_OK)
			if( pxRxBuffer != NULL )
				/* Where is the data? */
				netbuf_data( pxRxBuffer, ( void * ) &pcRxString, &usLength );
				/* Is this a GET?  We don't handle anything else. */
				if(( NULL != pcRxString)&& ( !strncmp( pcRxString, "GET", 3 ) ))
                	/* Write out the HTTP OK header. */
					netconn_write( pxNetCon, webHTTP_OK, (u16_t) strlen( webHTTP_OK ), NETCONN_COPY );
					strcpy( cDynamicPage, Webpage1 );
					netconn_write( pxNetCon, cDynamicPage, (u16_t) strlen( cDynamicPage ), NETCONN_COPY );
					strcpy( cDynamicPage, Webpage2 );
				if(( NULL != pcRxString) && ( !strncmp( pcRxString, "POST", 4 )))
					printf("\n\r%s",pcRxString);
					netbuf_delete( pxRxBuffer);
			netconn_close( pxNetCon );
			netconn_delete( pxNetCon );
rtel wrote on Tuesday, December 12, 2017:
I don’t think this is code we provided, or using our TCP stack. I would
recommend requesting support from whoever wrote the code.
heinbali01 wrote on Tuesday, December 12, 2017:
Hi Bob,
I’m reading your function prvweb_ParseHTMLRequest() :
Why does this function close and delete the connection? More requests might follow…
Instead of lwIP, you may also check out FreeRTOS+TCP
If you want the latest sources, you better download the official FreeRTOS release or have a look at https://aws.amazon.com/freertos
heinbali01 wrote on Wednesday, December 13, 2017:
The function that you are showing looks like sample code, a “hello world” for HTTP.
FreeRTOS+TCP contains a more complete example of a HTTP server, that keeps connections open. This server is still simple though, and it only implements the “GET” command.
It uses FreeRTOS+FAT to read files from either a RAM-disk or an SD-card.
The client browser will send a request as e.g. :
    GET /index.html HTTP/1.1
    Host: my_host
    Connection: keep-alive
The server will answer it:
    HTTP/1.1 200 OK
    Content-Type: text/html
    Content-Length: 6081
    "Contents ... " ( 6081 bytes )
It is possible that the browser sends a series of GET requests, without first waiting for the returning data.
Of course this technique is much more efficient than doing one request per TCP connection.
