nobody wrote on Wednesday, July 13, 2005:
I created a project for MC9S12DJ128B using metrowerks codewarrior v3.1
The issue is that when I created this project a prm file is generated which allocated
"RAM = READ_WRITE 0x0400 TO 0x1FFF;"
When I calculated the size, it is giving 7Kb whereas in the datasheet it specifies the RAM size to be 8Kb.
If this is the case, how can I make use of the rest 1Kb
