Why is portSAVE_CONTEXT() implemented as a macro, and not as a function?
I am going to use a PIC18F4550 but I was thinking: if I use a function instead of a macro, I can save a little bit RAM (pic18f4550 doesnt have much RAM), what do you think?
If portSAVE_CONTEXT was a function, then when it returned it would have to “unsave” the context to get to the return address, in one sense, portYIELD does that, save context, swap context, restore new context, and all works just fine. It is some what tricky programming (if it is possible) to make a function that you can call that returns to you and in the process saves the processor state on the stack, and even if you could write it, changing the stack in this manner in arbitrary places could give the compiler problems. This is one reason why the rules for how you right your ISRs can be very precise and tricky, as the save context macro needs to know the conditions it is being used to make things work.
Another issue is that it really wouldn’t save that much program memory, as there are normally only a few calls to this macro. As I mentioned, portYEILD does, and in some port, the interrupt handlers will call it. (on others the interrupt handlers call portYIELD to save the context).
