pierrechevalier wrote on Friday, May 16, 2014:
Do you have any idea about the gcc version that is used for the port ? I am using Sourcery G++ Lite 2010q1-188
rtel wrote on Friday, May 16, 2014:
I have never had a problem with any GCC compiler on a Cortex-M, unlike on the ARM 7 where there were multiple issues in various different versions. Provided the compiler complies with the EABI, which I believe that one does, there should not be a problem.
Occasionally they change the syntax required by the assembler, that is all, and problems like that show up at compile time, not run time.
Ok, I just tried with the last version and it still happen. I tested as you first said to put all irq to lowest priority (0xF) and I didn’t noticed a crash… so it must be an interrupt setting issue.
From the debugger I see in NVIC controller that priority are correctly set : 128 which means 8 for the interrupts that uses FreeRTOS functions, systick at 15, so configKERNEL_INTERRUPT_PRIORITY is correctly set, and configMAX_SYSCALL_INTERRUPT_PRIORITY is set to 3 (0x30 as the value in register), i checked in a critical section and basepri is set to 0x30 as well.
In traces I see that the systick critical section is not effective, an interrupt that calls xsemaphoregivefromisr is nested…
I will stop boring you with this, I’ll continue to work with priority set to lowest as it seems to be good this way… until I found what I did wrong.
Thanks for your help.
Best regards
grvgrv wrote on Wednesday, January 20, 2016:
Hi. Have you solved your issue ? It seems I have the same symptom, after few minutes running I get NULL in pxCurrentTCB and then BUS FAULT.
Anyone solved this issue?. Can anyone tell whats the root cause for this?
This thread is seven years old. Please create a new thread describing the problem you are facing.
