I have downloaded the “FreeRTOSv10.3.1.zip” and tried to run the demo of NiosII_CycloneIII_DBC3C40_GCC by following the steps given in the “https://www.freertos.org/FreeRTOS-Nios2.html”.
However, after importing to this into the NIOS II Eclipse IDE, when I select the “Build All” option, nothing is happening. Why this type of problem is arising?.
Any project setting is required to do it?.
I suspect this is because the format of the Eclipse project file in the download is too old for the version of the IDE you are using. Have you looked at the project settings (right click the project in the project explorer, click properties, then C/C++ Build, then settings too see).
Hello, @rtel I had the same doubt hence, I already tried with modifying some project settings like PATH variable, Toolchain selection but none of my changed settings are not worked.
I attached one zip file which consists of the default C/C++ build setting of the IDE.
Can you guide me to resolve this issue?. C_C _Build_Settings.zip (407.0 KB) Which settings are wrong and need to modify?.
Thank you so much @asiddiqui…!! I will try your suggested steps once I have time to test it. I am little bit busy with other task. If facing any issue during the test step as you have performed, I will get back to you.
Hello AP_040
I have no idea why it’s giving this error, i got the error but that was memory problem, then i switch to SDRAM from onchip memory and problem was solved
