amarjith wrote on Friday, November 08, 2013:
Automatic resetting occurs when i add/ create some tasks for example if i add xTaskCreate( vHandlerTask, “Handler”, 500, NULL, 1, NULL);
in my program microcontroller will reset automatically
void vHandlerTask( void pvParameters )
int i;
/ As per most tasks, this task is implemented within an infinite loop. /
for( ;; )
U1_puts( “Handler task .\r\n” );
/ Use the semaphore to wait for an event. The semaphore was created
before the scheduler was started so before this task ran for the first
time. The task blocks indefinitely so the function call will only
return once the semaphore has been successfully taken (obtained). There
is therefore no need to check the function return value. /
xSemaphoreTake( xBinarySemaphore, portMAX_DELAY );
/ To get here the event must have occurred. Process the event.
case processing is simply a matter of printing out a message. */
U1_puts( “Handler task - Processing event.\r\n” );
Why this happening when adding some tasks?, if i delete or comment this task program will work. Please help
These are my Tasks if i put tasks as shown below “vMT_InitRepman” will execute first , it never enter in to vHandlerTask even its priority is 10.
xTaskCreate( vMT_InitRepman, "vMT_InitRepman", 500, NULL, 3, &xInitHandle );
xTaskCreate( vMT_Loging, "vMT_Loging", 500, 5, 1, &xLogingHandle);
xTaskCreate( vMT_Upload, "vMT_Upload", 500, 20, 1, &xUploadHandle );
xTaskCreate( vMT_ErrorHandler, "vMT_ErrorHandler", 500, NULL, 2, &xErrorHandle );
xTaskCreate( vHandlerTask, "Handler", 500, NULL, 10, NULL);
And if put as shown below, microcontroller will reset continuously
