# OTA update using green grass server
**URL:** <https://forums.freertos.org/t/ota-update-using-green-grass-server/10825>\
**Category:** AWS\
**Created:** [October 5, 2020, 10:03am UTC](https://forums.freertos.org/t/ota-update-using-green-grass-server/10825 "2020-10-05T10:03:22Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![Radrud](https://avatars.discourse-cdn.com/v4/letter/r/73ab20/32.png) [@Radrud](https://forums.freertos.org/u/Radrud)\
**Post date:** [October 5, 2020, 10:03am UTC](https://forums.freertos.org/t/ota-update-using-green-grass-server/10825/1 "2020-10-05T10:03:22Z")
</div>
I could able to successfully run the OTA update demo with the help of relevant documentation,
But in our system all the devices(things) will not talk directly to the cloud but through green grass server,
We made a design decision considering other application requirements that all the data flow between the AWS cloud server and the devices should happen only through green grass,
in this scenario , how implement over the air update of all the devices from AWS cloud through the green gross,
I couldn’t find any documentation addressing this scenario.
Please guide me
**Author:** ![rtel](https://d3iykfbgfh8zhg.cloudfront.net/user_avatar/forums.freertos.org/rtel/32/31_2.png) [@rtel](https://forums.freertos.org/u/rtel)\
**Post date:** [October 5, 2020, 10:16pm UTC](https://forums.freertos.org/t/ota-update-using-green-grass-server/10825/2 "2020-10-05T22:16:11Z")
</div>
Are you wanting to use the AWS OTA service for FreeRTOS ([https://docs.aws.amazon.com/freertos/latest/userguide/freertos-ota-dev.html](https://docs.aws.amazon.com/freertos/latest/userguide/freertos-ota-dev.html)) - or do you have your own OTA mechanism?
**Post date:** [October 6, 2020, 4:38am UTC](https://forums.freertos.org/t/ota-update-using-green-grass-server/10825/3 "2020-10-06T04:38:50Z")
</div>
Currently I am planning to use AWS ota service
**Author:** ![aggarg](https://d3iykfbgfh8zhg.cloudfront.net/user_avatar/forums.freertos.org/aggarg/32/4245_2.png) [@aggarg](https://forums.freertos.org/u/aggarg)\
**Post date:** [October 7, 2020, 12:35am UTC](https://forums.freertos.org/t/ota-update-using-green-grass-server/10825/4 "2020-10-07T00:35:31Z")
</div>
We do not have samples showing how to do OTA using GreenGrass but I was able to achieve it in the past by making some changes as I mentioned in this post: [Mege OTA and greengrass demo together](https://forums.freertos.org/t/mege-ota-and-greengrass-demo-together/8947/20)
