Hi @ddeyo ,
2 things can be done here:
- Capture the ethernet frames using wireshark and see what is exactly happening when the issue occurs.
- Take a dump of MAC registers when everything is running fine and in issue state and compare the same.
These mostly likely will give some good pointers.
Thanks,
Shub
