@txf For optimal performance, it would be best to set your esp_tls connection to non-blocking mode and use select() to wait for an incoming message of any size rather than the default behavior of esp_tls_conn_read which attempts to fill the entire buffer up until the timeout.
When initializing your esp_tls connection, be set to set the non_block field to true.
You can get the current socket handle using the esp_tls_get_conn_sockfd() function call and from there, do something like the following:
int32_t espTlsTransportRecv(NetworkContext_t* pxNetworkContext,
void* pvData, size_t uxDataLen)
int32_t lBytesRead = -1;
if( ( pvData != NULL ) &&
( uxDataLen > 0 ) &&
( pxNetworkContext != NULL ) &&
( pxNetworkContext->pxTls != NULL ) )
int lSockFd = -1;
// TODO: Is a semaphore really necessary here?
xSemaphoreTake(pxNetworkContext->xTlsContextSemaphore, portMAX_DELAY);
lSockFd = esp_tls_get_conn_sockfd(pxNetworkContext->pxTls);
xSemaphoreGive(pxNetworkContext->xTlsContextSemaphore);
if( lSockFd >= 0 )
int lResult = -1;
fd_set xReadSet;
fd_set xErrorSet;
FD_SET(sockFd, &xReadSet);
FD_SET(sockFd, &xErrorSet);
// TODO: set a timeout for the select call
lResult = select(sockFd + 1, &xReadSet, NULL, &xErrorSet, NULL );
if( ( lResult > 0 ) &&
FD_ISSET( sockFd, &xReadSet ) )
lBytesRead = ( int32_t ) esp_tls_conn_read(pxNetworkContext->pxTls, pvData, uxDataLen);
else if( ( lResult == -1 ) &&
FD_ISSET( sockFd, &xErrorSet ) )
/* Socket Error */
lBytesRead = -1;
lBytesRead = 0;
if( ( lBytesRead == ESP_TLS_ERR_SSL_WANT_WRITE ) ||
( lBytesRead == ESP_TLS_ERR_SSL_WANT_READ) ) {
lBytesRead = 0;
return lBytesRead;
Be sure to use the latest version of coreMQTT for best results. Previous versions had a bug which prevented proper handling of messages that arrive across multiple calls to the transport receive function.
