I have tried to share a MQTT Connection via Greengrass with the OTA Agent.
From what I see, you get the same errors as I do:
"438 3328 [OTA Task] [OTA_CheckForUpdate] Failed to publish MQTT message."
This message corresponds to a message on greengrass(from my logs):
"[2019-09-25T00:26:08.19+02:00][ERROR]-MQTT QoS Error: Greengrass does not support QoS 1."
The message in the greengrass logs always occurs near the message on the esp32 from the OTA Task.
The OTA Task wants to use QOS1, Greengrass only supports QOS0, so , OTA over GG, no can do.
Look in the greengrass logs for yourself with:
tail -f /greengrass/ggc/var/log/system/*.log /greengrass/ggc/var/log/system/localwatch/localwatch.log
If you supply the OTA Agent with a MQTT Connection directly to the IoT Backend, all is fine, you can use the same client id/certs etc. in this case.
The clientid must be unique +per Broker+, so you can connect to GG and the cloud with the same id because the two are different brokers.
What seems to work now, is sharing an MQTT connection for Thing Shadow and normal MQTT to the same broker, both for Greengrass and IoT Backend. This is an aw(e|s)some piece of work and removes the need for a third Mqtt connection, if you want to do ota, shadow and mqtt to aws at the same time.
I am using a timertask to switch between “normal operations” and “go look for an ota update” mode to keep memory usage down.
What I mentioned in the above post is that after changing the OTA agent to use QoS0 instead of QoS1 and establishing the above mentioned subscriptions in the Greengrass group, sharing MQTT connection to Greengrass core for OTA works for me.
I have changed the QOS Settings in the ota_agent.c file and now the ota updates work in parallel to the shadow updates on one mqtt connection over greengrass and also if the mqtt connection is directly connected to the cloud.
That is really cool ! Thank you.
I did not create a separate OTA task but looking at the code you shared in the beginning of this post, Greengrass publishes should work. Here are the few things to check:
Do you have the required subscription in your Greengrass group i.e. from device to cloud for topic “freertos/demos/ggd”?
Is MQTT_AGENT_Publish in the function prvSendMessageToGGC is being called? You can check that by putting a log message before calling MQTT_AGENT_Publish.
Subscribe to the topic “freertos/demos/ggd” on the AWS IoT console to see if those messages are being published. Note that the demo only publishes 3 messages which is configured using the ggdDEMO_MAX_MQTT_MESSAGES macro.
Yes, you can create a PR that way. However, we would probably want to make the change in a more configureable way rather than changing them to QoS0. I have asked my colleagues to take a look and see if they can address it.
By following the mentioned updates and creating the new subscriptions, requesting OTA job information is now possible.
However I got an error in receiving one block and this cause the connection to be closed!
670 15713 [iot_thread] State: Active Received: 200 Queued: 200 Processed: 200 Dropped: 0
671 15807 [OTA Task] [prvIngestDataBlock] Received file block 202, size 1024
672 15808 [OTA Task] [prvIngestDataBlock] Remaining: 670
673 15808 [OTA Task] [prvIngestDataBlock] Received file block 203, size 1024
674 15808 [OTA Task] [prvIngestDataBlock] Remaining: 669
675 15833 [iot_thread] WAHDAN : vRunOTAUpdateDemo : Inside the while loop
676 15833 [iot_thread] State: Active Received: 202 Queued: 202 Processed: 202 Dropped: 0
677 15953 [iot_thread] WAHDAN : vRunOTAUpdateDemo : Inside the while loop
678 15953 [iot_thread] State: Active Received: 202 Queued: 202 Processed: 202 Dropped: 0
679 16058 [OTA Task] [INFO ][MQTT][160580] (MQTT connection 0x3fff2190) MQTT PUBLISH operation queued.
680 16058 [OTA Task] [prvPublishGetStreamMessage] OK: $aws/things/HelloWorld_Publisher/streams/AFR_OTA-2374f622-5de3-4930-
8cbe-4e9d5d508b0d/get/cbor
681 16060 [OTA Task] [prvIngestDataBlock] Received file block 204, size 1024
682 16060 [OTA Task] [prvIngestDataBlock] Remaining: 668
683 16073 [iot_thread] WAHDAN : vRunOTAUpdateDemo : Inside the while loop
684 16073 [iot_thread] State: Active Received: 203 Queued: 203 Processed: 203 Dropped: 0
685 16193 [iot_thread] WAHDAN : vRunOTAUpdateDemo : Inside the while loop
686 16193 [iot_thread] State: Active Received: 203 Queued: 203 Processed: 203 Dropped: 0
687 16260 [NetRecv] [ERROR][NET][162600] Error 0 while receiving data.
688 16260 [NetRecv] [WARN ][NET][162600] Receive requested 1140 bytes, but 97 bytes received instead.
689 16260 [NetRecv] [ERROR][MQTT][162600] (MQTT connection 0x3fff2190) Error processing incoming data. Closing connection.
690 16261 [NetRecv] [INFO ][MQTT][162610] (MQTT connection 0x3fff2190) Network connection closed.
691 16309 [OTA Task] [WARN ][MQTT][163090] (MQTT connection 0x3fff2190) Attempt to use closed connection.
692 16309 [OTA Task] [ERROR][MQTT][163090] (MQTT connection 0x3fff2190) New operation record cannot be created for a close
d connection
693 16309 [OTA Task] [prvPublishGetStreamMessage] Failed: $aws/things/HelloWorld_Publisher/streams/AFR_OTA-2374f622-5de3-4
930-8cbe-4e9d5d508b0d/get/cbor
694 16313 [iot_thread] WAHDAN : vRunOTAUpdateDemo : Inside the while loop
695 16313 [iot_thread] State: Active Received: 203 Queued: 203 Processed: 203 Dropped: 0
696 16433 [iot_thread] WAHDAN : vRunOTAUpdateDemo : Inside the while loop
697 16433 [iot_thread] State: Active Received: 203 Queued: 203 Processed: 203 Dropped: 0
698 16553 [iot_thread] WAHDAN : vRunOTAUpdateDemo : Inside the while loop
699 16553 [iot_thread] State: Active Received: 203 Queued: 203 Processed: 203 Dropped: 0
700 16559 [OTA Task] [WARN ][MQTT][165590] (MQTT connection 0x3fff2190) Attempt to use closed connection.
701 16559 [OTA Task] [ERROR][MQTT][165590] (MQTT connection 0x3fff2190) New operation record cannot be created for a close
d connection
702 16559 [OTA Task] [prvPublishGetStreamMessage] Failed: $aws/things/HelloWorld_Publisher/streams/AFR_OTA-2374f622-5de3-4
Edit:
This also occurs with the normal OTA demo, this might be related to the QOS0 that we changes, I don’t know!
Edit2:
I have successful OTA update through greengrass.
I think this may be kind of race condition!
Shouldn’t this case be handled, like dropping this packet and re-request?
Another issue is that the first connection to IOT core to retrieve the Greengrass core information works, but the second time fails with network_error and I need to restart the router(in my case I use the mobile as access point), and it doesn’t matter if I closed the connection or not, any ideas?
