So I set a break point at
port.c
line:1652 configASSERT( pxVectorTable[ portVECTOR_INDEX_SVC ] == SVC_Handler );
line:1758 vStartFirstTask();
line:1130 vRestoreContextOfFirstTask();
The first that was hit was line 1652.
A couple observations, when I load the Vector Table into RAM, and start the kernel via vStartScheduler and then stop the code execution, the PC jumps to:
void PendSV_Handler( void ) /* __attribute__ (( naked )) PRIVILEGED_FUNCTION */
PC HERE {
__asm volatile
" .syntax unified \n"
" \n"
" mrs r0, psp \n" /* Read PSP in r0. */
" \n"
#if ( ( configENABLE_FPU == 1 ) || ( configENABLE_MVE == 1 ) )
" tst lr, #0x10 \n" /* Test Bit[4] in LR. Bit[4] of EXC_RETURN is 0 if the Extended Stack Frame is in use. */
" it eq \n"
" vstmdbeq r0!, {s16-s31} \n" /* Store the additional FP context registers which are not saved automatically. */
#endif /* configENABLE_FPU || configENABLE_MVE */
" \n"
" mrs r2, psplim \n" /* r2 = PSPLIM. */
" mov r3, lr \n" /* r3 = LR/EXC_RETURN. */
" stmdb r0!, {r2-r11} \n" /* Store on the stack - PSPLIM, LR and registers that are not automatically saved. */
" \n"
" ldr r2, =pxCurrentTCB \n" /* Read the location of pxCurrentTCB i.e. &( pxCurrentTCB ). */
" ldr r1, [r2] \n" /* Read pxCurrentTCB. */
" str r0, [r1] \n" /* Save the new top of stack in TCB. */
" \n"
" mov r0, %0 \n" /* r0 = configMAX_SYSCALL_INTERRUPT_PRIORITY */
" msr basepri, r0 \n" /* Disable interrupts upto configMAX_SYSCALL_INTERRUPT_PRIORITY. */
" dsb \n"
" isb \n"
" bl vTaskSwitchContext \n"
" mov r0, #0 \n" /* r0 = 0. */
" msr basepri, r0 \n" /* Enable interrupts. */
" \n"
" ldr r0, [r1] \n" /* The first item in pxCurrentTCB is the task top of stack. r0 now points to the top of stack. */
" \n"
" ldmia r0!, {r2-r11} \n" /* Read from stack - r2 = PSPLIM, r3 = LR and r4-r11 restored. */
" \n"
" tst r3, #0x10 \n" /* Test Bit[4] in LR. Bit[4] of EXC_RETURN is 0 if the Extended Stack Frame is in use. */
" it eq \n"
" vldmiaeq r0!, {s16-s31} \n" /* Restore the additional FP context registers which are not restored automatically. */
" \n"
" msr psplim, r2 \n" /* Restore the PSPLIM register value for the task. */
" msr psp, r0 \n" /* Remember the new top of stack for the task. */
" bx r3 \n"
::"i" ( configMAX_SYSCALL_INTERRUPT_PRIORITY )
However, if I don’t load the vector table into RAM, and I start the kernel via vStartScheduler() and then stop the execution, the PC is at:
#if ( configCHECK_HANDLER_INSTALLATION == 1 )
const portISR_t * const pxVectorTable = portSCB_VTOR_REG;
/* Validate that the application has correctly installed the FreeRTOS
* handlers for SVCall and PendSV interrupts. We do not check the
* installation of the SysTick handler because the application may
* choose to drive the RTOS tick using a timer other than the SysTick
* timer by overriding the weak function vPortSetupTimerInterrupt().
* Assertion failures here indicate incorrect installation of the
* FreeRTOS handlers. For help installing the FreeRTOS handlers, see
* https://www.FreeRTOS.org/FAQHelp.html.
* Systems with a configurable address for the interrupt vector table
* can also encounter assertion failures or even system faults here if
* VTOR is not set correctly to point to the application's vector table. */
PC HERE configASSERT( pxVectorTable[ portVECTOR_INDEX_PENDSV ] == PendSV_Handler );
