I appreciate that you want to help me and I would like to thank you in advance!
This is my freertos.c where I am using stack and queue(In order to communicate with the UI).
osThreadId_t defaultTaskHandle;
const osThreadAttr_t defaultTask_attributes = {
.name = "defaultTask",
.stack_size = 9000 * 4,
.priority = (osPriority_t) osPriorityNormal,
void StartDefaultTask(void *argument)
/* init code for USB_HOST */
MX_USB_HOST_Init();
/* init code for LWIP */
MX_LWIP_Init();
/* USER CODE BEGIN StartDefaultTask */
err_t err;
ip_addr_t mqttIP;
struct mqtt_connect_client_info_t ci; // Create an information parameter about the client.
flag0.clear_flags = 0; // Clear all flags.
memset(&ci, 0, sizeof(ci)); // Initialize the parameter for client information and set the all 0 to entire size of ci.
/* Declare information about the client */
ci.client_id = "STM32H7-R"; // It is important to be unique. It doesn't matter if it is a random string but it must be unique as I said.
client=mqtt_client_new(); // Initialize the new client instance.
if (client != NULL){
ipaddr_aton("192.168.10.26",&mqttIP);
mqtt_client_connect(client, &mqttIP, BROKER_PORT, mqtt_connection_cb, 0, &ci); // Connect with the server IP:192.168.10.26
for(;;){
if (mqtt_client_is_connected(client)){
// Client is connected
if (status){ // If something must be send to the UI
osMessageQueuePut(QueueHandle, &action, 0, 0); // Send the data, which is representing the struct through the queue.
status=0; // Close the port="status"
osDelay(1);
/* Infinite loop */
/* USER CODE END StartDefaultTask */
static void mqtt_incoming_data_cb(void *arg, const u8_t *data, u16_t len, u8_t flags)
char buf[len+1]; // Declare a buffer where the messages will be stored
strncpy(buf, (char *)data, len); // Initialize buffer buf with the value of incoming data
buf[len]='\0'; // Set a terminate character into the the end of buffer
if (flags & MQTT_DATA_FLAG_LAST){
// When the last byte received
if (flag0.fl.f2){ // If the left state is open
flag0.fl.f3=0;// Close the right state while you are open
strncpy(action.left_state, buf, len); // Copy the value to the proper path of the struct
flag0.fl.f2 = 0; // Close the state
if (flag0.fl.f3){ // If the right state is open
flag0.fl.f2=0;// Close the left state while you are open
strncpy(action.right_state, buf, len); // Copy the value to the proper path of the struct
flag0.fl.f3 = 0; // Close the state
if (flag0.fl.f4){ // If the right energy is open
flag0.fl.f5=0;
//parseRightJSON(buf); // Call the function in order to extract data
flag0.fl.f4=0; // Close the energy
if (flag0.fl.f5){ // If the left energy is open
parseLeftJSON(buf); // Call the function in order to extract data
flag0.fl.f5=0; // Close the energy
if (flag0.fl.f6){ // If right time is open
flag0.fl.f7=0;
setRightTime(buf, len, 2); // Send the seconds to the proper function in order to create time
flag0.fl.f6=0; // Close the time
if (flag0.fl.f7){ // If the left time is open
flag0.fl.f6=0;
setLeftTime(buf, len, 1); // Send the seconds to the proper function in order to create time
flag0.fl.f7=0; // Close the time
status=1; // Inform the engine that you have something to send to UI, by opening the port="status"
static void mqtt_incoming_publish_cb(void *arg, const char *topic, u32_t tot_len)
if (strcmp(topic, state_left)==0){
flag0.fl.f2=1; // Store left state
}else if (strcmp(topic, state_right)==0){
flag0.fl.f3=1; // Store right state
}else if (strcmp(topic, right_energy_topic)==0){
flag0.fl.f4=1; // Store right energy data
}else if (strcmp(topic, left_energy_topic)==0){
flag0.fl.f5=1; // Store left energy data
}else if (strcmp(topic, left_time)==0){
flag0.fl.f7=1; // Store left charging time
}else if (strcmp(topic, right_time)==0){
flag0.fl.f6=1; // Store right charging time
Furthermore, my linkerscript is like this:
** File : LinkerScript.ld
** Author : STM32CubeIDE
** Abstract : Linker script for STM32H7 series
** 1024Kbytes FLASH
** 800Kbytes RAM
** Set heap size, stack size and stack location according
** to application requirements.
** Set memory bank area and size if external memory is used.
** Target : STMicroelectronics STM32
** Distribution: The file is distributed as is without any warranty
** of any kind.
** @attention
** Copyright (c) 2023 STMicroelectronics.
** All rights reserved.
** This software is licensed under terms that can be found in the LICENSE file
** in the root directory of this software component.
** If no LICENSE file comes with this software, it is provided AS-IS.
/* Entry Point */
ENTRY(Reset_Handler)
/* Highest address of the user mode stack */
_estack = ORIGIN(RAM_D1) + LENGTH(RAM_D1); /* end of "RAM_D1" Ram type memory */
_Min_Heap_Size = 0xc000 ; /* required amount of heap */
_Min_Stack_Size = 0x8000; /* required amount of stack */
/* Memories definition */
MEMORY
RAM_D1 (xrw) : ORIGIN = 0x24000000, LENGTH = 512K
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024K /* Memory is divided. Actual start is 0x08000000 and actual length is 2048K */
DTCMRAM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K
RAM_D2 (xrw) : ORIGIN = 0x30000000, LENGTH = 288K
RAM_D3 (xrw) : ORIGIN = 0x38000000, LENGTH = 64K
ITCMRAM (xrw) : ORIGIN = 0x00000000, LENGTH = 64K
QUADSPI (r) : ORIGIN = 0x90000000, LENGTH = 64M
SDRAM (xrw) : ORIGIN = 0xD0000000, LENGTH = 3600K
SDRAM2 (xrw) : ORIGIN = 0xD0384000, LENGTH = 4592K
/* Sections */
SECTIONS
/* The startup code into "FLASH" Rom type memory */
.isr_vector :
. = ALIGN(4);
KEEP(*(.isr_vector)) /* Startup code */
. = ALIGN(4);
} >FLASH
/* The program code and other data into "FLASH" Rom type memory */
.text :
. = ALIGN(4);
*(.text) /* .text sections (code) */
*(.text*) /* .text* sections (code) */
*(.glue_7) /* glue arm to thumb code */
*(.glue_7t) /* glue thumb to arm code */
*(.eh_frame)
KEEP (*(.init))
KEEP (*(.fini))
. = ALIGN(4);
_etext = .; /* define a global symbols at end of code */
} >FLASH
/* Constant data into "FLASH" Rom type memory */
.rodata :
. = ALIGN(4);
*(.rodata) /* .rodata sections (constants, strings, etc.) */
*(.rodata*) /* .rodata* sections (constants, strings, etc.) */
. = ALIGN(4);
} >FLASH
.ARM.extab : {
. = ALIGN(4);
*(.ARM.extab* .gnu.linkonce.armextab.*)
. = ALIGN(4);
} >FLASH
.ARM : {
. = ALIGN(4);
__exidx_start = .;
*(.ARM.exidx*)
__exidx_end = .;
. = ALIGN(4);
} >FLASH
.preinit_array :
. = ALIGN(4);
PROVIDE_HIDDEN (__preinit_array_start = .);
KEEP (*(.preinit_array*))
PROVIDE_HIDDEN (__preinit_array_end = .);
. = ALIGN(4);
} >FLASH
.init_array :
. = ALIGN(4);
PROVIDE_HIDDEN (__init_array_start = .);
KEEP (*(SORT(.init_array.*)))
KEEP (*(.init_array*))
PROVIDE_HIDDEN (__init_array_end = .);
. = ALIGN(4);
} >FLASH
.fini_array :
. = ALIGN(4);
PROVIDE_HIDDEN (__fini_array_start = .);
KEEP (*(SORT(.fini_array.*)))
KEEP (*(.fini_array*))
PROVIDE_HIDDEN (__fini_array_end = .);
. = ALIGN(4);
} >FLASH
/* Used by the startup to initialize data */
_sidata = LOADADDR(.data);
/* Initialized data sections into "RAM" Ram type memory */
.data :
. = ALIGN(4);
_sdata = .; /* create a global symbol at data start */
*(.data) /* .data sections */
*(.data*) /* .data* sections */
*(.RamFunc) /* .RamFunc sections */
*(.RamFunc*) /* .RamFunc* sections */
. = ALIGN(4);
_edata = .; /* define a global symbol at data end */
} >RAM_D1 AT> FLASH
/* Uninitialized data section into "RAM" Ram type memory */
. = ALIGN(4);
.bss :
/* This is used by the startup in order to initialize the .bss section */
_sbss = .; /* define a global symbol at bss start */
__bss_start__ = _sbss;
*(.bss)
*(.bss*)
*(COMMON)
. = ALIGN(4);
_ebss = .; /* define a global symbol at bss end */
__bss_end__ = _ebss;
} >RAM_D1
/* User_heap_stack section, used to check that there is enough "RAM" Ram type memory left */
._user_heap_stack :
. = ALIGN(8);
PROVIDE ( end = . );
PROVIDE ( _end = . );
. = . + _Min_Heap_Size;
. = . + _Min_Stack_Size;
. = ALIGN(8);
} >RAM_D1
/* Remove information from the compiler libraries */
/DISCARD/ :
libc.a ( * )
libm.a ( * )
libgcc.a ( * )
.lwip_sec (NOLOAD) :
. = ABSOLUTE(0x30000000);
*(.RxDecripSection)
. = ABSOLUTE(0x30000200);
*(.TxDecripSection)
. = ABSOLUTE(0x30031100);
*(.RxPool)
} >RAM_D2
.ARM.attributes 0 : { *(.ARM.attributes) }
TouchGFX_Framebuffer (NOLOAD) :
*(TouchGFX_Framebuffer TouchGFX_Framebuffer.*)
*(.gnu.linkonce.r.*)
. = ALIGN(0x4);
} >SDRAM
BufferSection (NOLOAD) :
*(Video_RGB_Buffer Video_RGB_Buffer.*)
. = ALIGN(0x4);
} >SDRAM2
ExtFlashSection :
*(ExtFlashSection ExtFlashSection.*)
. = ALIGN(0x4);
} >QUADSPI
And also my MPU region configurations are like this:
void MPU_Config(void)
MPU_Region_InitTypeDef MPU_InitStruct = {0};
/* Disables the MPU */
HAL_MPU_Disable();
/** Initializes and configures the Region and the memory to be protected
MPU_InitStruct.Enable = MPU_REGION_ENABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER0;
MPU_InitStruct.BaseAddress = 0x30000000;
MPU_InitStruct.Size = MPU_REGION_SIZE_1KB;
MPU_InitStruct.SubRegionDisable = 0x0;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
HAL_MPU_ConfigRegion(&MPU_InitStruct);
MPU_InitStruct.Number = MPU_REGION_NUMBER1;
MPU_InitStruct.BaseAddress = 0x30004000;
MPU_InitStruct.Size = MPU_REGION_SIZE_16KB;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1;
MPU_InitStruct.IsShareable = MPU_ACCESS_SHAREABLE;
MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
/* Enables the MPU */
HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
