LPC2368 with MCB2300, GCC, Ethernet example
rrv44 wrote on Thursday, May 03, 2012:
Hello all!
I am using MCB2300 with LPC2368 microcontroller inside, using Keil uVision development tool with GCC compiler.
What I am trying to do is to incorporate Rowley Ethernet example, but I am finding some linking problems I can´t tackle.
I would appreciate very much if any of you had this example working and could send me the project to try to start from it.
Thank you very much for your help!
Kind regards,
Ruben.
davedoors wrote on Thursday, May 03, 2012:
What are the linking problems?
It is wierd, because it should try to access /GNU_obj instead of /obj, but, in any case, .elf file is not in any of the directories…
Thanks, Dave!
linking…
c:/winarm/bin/…/lib/gcc/arm-elf/4.1.1/…/…/…/…/arm-elf/bin/ld.exe: .\\obj: No such file: Permission denied
collect2: ld returned 1 exit status
creating hex file…
arm-elf-objcopy: ‘.\Obj_GNU\usbdev.elf’: No such file
arm-elf-objcopy: error: the input file ‘.\Obj_GNU\usbdev.elf’ is empty
rrv44 wrote on Wednesday, May 09, 2012:
FInally, I managed to have the compilation up and running but, unfortunately, when I load it onto the platform, it just does nothing… :frowning:
