verretj wrote on Wednesday, November 19, 2008:
I use my own startup code, and made several modifications so thait I start in supervisor mode and the swi branch to vPortYieldProcessor.
I am going to compare it to the one from LPC2209 and see if anything misses. Here is my startup code if you have the courage to go through it.
/* Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs */
.equ Mode_USR, 0x10
.equ Mode_FIQ, 0x11
.equ Mode_IRQ, 0x12
.equ Mode_SVC, 0x13
.equ Mode_ABT, 0x17
.equ Mode_UND, 0x1B
.equ Mode_SYS, 0x1F /* only available on ARM Arch >= v4 */
.equ I_Bit, 0x80 /* when I bit is set, IRQ is disabled */
.equ F_Bit, 0x40 /* when F bit is set, FIQ is disabled */
/* — Stack Sizes ----------------------- */
.equ Top_Stack, 0x40004000
.equ UND_Stack_Size, 0x00000004
.equ ABT_Stack_Size, 0x00000004
.equ FIQ_Stack_Size, 0x00000004
.equ IRQ_Stack_Size, 0x00000400
.equ USR_Stack_Size, 0x00000004
.equ SYS_Stack_Size, 0x00000004
.equ SVC_Stack_Size, 0x00000400
/* — Peripheral’s registers ------------ */
.equ VICIntEnClr, 0xFFFFF014
.equ VICVectAddr, 0xFFFFF030
.text
.arm
.global _start
.global cksum_size /* at 0x00000040 */
.global cksum_expected /* at 0x00000044 */
_start:
/* Exception Vectors (mapped to address 0) */
Vectors: LDR PC, Reset_Addr
LDR PC, Undef_Addr
LDR PC, SWI_Addr
LDR PC, PAbt_Addr
LDR PC, DAbt_Addr
.word 0xB9205F80 /* Program signature (LPC21xx) */
LDR PC, [PC, #-0x0FF0] /* Vector from VicVectAddr reg */
LDR PC, FIQ_Addr
Reset_Addr: .word Reset_Handler
Undef_Addr: .word Undef_Handler
SWI_Addr: .word SWI_Handler
PAbt_Addr: .word PAbt_Handler
DAbt_Addr: .word DAbt_Handler
.word 0 /* not used */
IRQ_Addr: .word IRQ_Handler /* not used */
FIQ_Addr: .word FIQ_Handler
cksum_size: .word 0xDEADBEEF /* needed for S04_01A_cksum_maker.exe */
cksum_expected: .word 0xCAFEFACE /* and S04_01A firmware for test #1 */
/* Dummy handlers */
Undef_Handler: B Undef_Handler
SWI_Handler: B vPortYieldProcessor
PAbt_Handler: B PAbt_Handler
DAbt_Handler: B DAbt_Handler
IRQ_Handler: B IRQ_Handler /* not used */
FIQ_Handler: B FIQ_Handler
Reset_Handler:
/* — First initialize the VIC (Vectored Interrupt Controller) ----------- */
LDR R0, =VICIntEnClr
MOV R1, #0xFFFFFFFF
STR R1, [R0]
LDR R0, =VICVectAddr
MOV R1, #0xFF
STR R1, [R0]
/* — Setup Stack for each mode ----------------------------------------- */
LDR R0, =Top_Stack
/* Enter Undefined instruction mode and set up the UND stack pointer */
MSR CPSR_c, #Mode_UND | I_Bit | F_Bit
MOV SP, R0
SUB R0, R0, #UND_Stack_Size
/* Enter ABT mode and set up the ABT stack pointer */
MSR CPSR_c, #Mode_ABT | I_Bit | F_Bit
MOV SP, R0
SUB R0, R0, #ABT_Stack_Size
/* Enter FIQ mode and set up the FIQ stack pointer */
MSR CPSR_c, #Mode_FIQ | I_Bit | F_Bit
MOV SP, R0
SUB R0, R0, #FIQ_Stack_Size
/* Enter IRQ mode and set up the IRQ stack pointer */
MSR CPSR_c, #Mode_IRQ | I_Bit | F_Bit
MOV SP, R0
SUB R0, R0, #IRQ_Stack_Size
/* Enter SYS mode and set up the SYS stack pointer */
MSR CPSR_c, #Mode_SYS | I_Bit | F_Bit
MOV SP, R0
SUB R0, R0, #SYS_Stack_Size
/* Enter SVC mode and set up the SVC stack pointer (we stay in SVC mode with interrupts enabled) */
MSR CPSR_c, #Mode_SVC | I_Bit | F_Bit
MOV SP, R0
SUB R0, R0, #SVC_Stack_Size
/* Enter User mode then set up its stack */
/* MSR CPSR_c, #Mode_USR
MOV SP, R0
SUB R0, R0, #USR_Stack_Size
# Setup a default Stack Limit (when compiled with "-mapcs-stack-check")
SUB SL, SP, #USR_Stack_Size*/
/* Start in supervisor mode(needed by Free RTOS) */
/* MSR CPSR_c, #Mode_SVC|I_Bit|F_Bit*/
# — Relocate .data section (copy from ROM to RAM) -------------------------
LDR R1, =_etext
LDR R2, =_data
LDR R3, =_edata
Loop_Rel: CMP R2, R3
LDRLO R0, [R1], #4
STRLO R0, [R2], #4
BLO Loop_Rel
# — Clear .bss section (Zero Init) ----------------------------------------
MOV R0, #0
LDR R1, =__bss_start__
LDR R2, =__bss_end__
Loop_ZI: CMP R1, R2
STRLO R0, [R1], #4
BLO Loop_ZI
# — Enter C code ----------------------------------------------------------
BL main
main_exited: B main_exited
.end
