LPC2119 IAR Demo error
richas wrote on Thursday, April 12, 2018:
New to FreeRTOS. Trying to build the LPC2129 demo project in IAR.
I get this error:
Error[25]: #error 'This file should only be compiled by ICCARM/AARM
Fiddled with the compiler settings to no avail.
Thanks
Rich
rtel wrote on Thursday, April 12, 2018:
Can you please post which file this is in.
portasm.s79 an assembler error
Thanks
Hmm, I can’t find a copy of that file with that #error message in. I’m
going to assume it is coming from the fact that the asm file in
including FreeRTOSConfig.h, and that FreeRTOSConfig.h in including
iolpc2129.h - in which case the #error might be in iolpc2129.h.
Alternatively it might be a compiler version mismatch issue.
If iolpc2129.h contains something the assembler can’t cope with then you
can use a guard around the header to ensure it is only included when .c
files are compiler rather than assembly files:
#ifdef __ICCARM__
#include
Richard,
That was nice bit of sleuthing! Adding the compile conditional to FreeRTOSConfig.h allows it to build.
Onward and thank you
Rich
