So I updated to the latest version on the master branch and I’m still getting the exact same issues as described above. Any other suggestions?
My src/CMakeLists.txt
add_compile_options(-w)
cmake_minimum_required(VERSION 3.13)
project(freertos_examples)
add_executable(esp32_app src/main.c)
# Tell IDF build to link against this target.
set(IDF_PROJECT_EXECUTABLE esp32_app)
# Add some extra components. IDF_EXTRA_COMPONENT_DIRS is an variable used by ESP-IDF
# to collect extra components.
get_filename_component(EXTRA_COMPONENT_DIRS components ABSOLUTE)
# Add some external components to the project
set(IDF_EXTRA_COMPONENT_DIRS ${EXTRA_COMPONENT_DIRS})
# As of now there's no offical way to redefine config files outside of Amazon FreeRTOS source tree.
# This is a temporary approach to inject an include path so that this takes precedence over the
# config file directory inside Amazon FreeRTOS.
include_directories(BEFORE amazon-freertos-configs)
# Add amazon freertos as an subdirectory. AFR_BOARD tells which board to target.
set(AFR_BOARD espressif.esp32_devkitc CACHE INTERNAL "")
add_subdirectory(amazon-freertos)
target_link_libraries(esp32_app PRIVATE AFR::demo_mqtt)
target_link_libraries(esp32_app PRIVATE 3rdparty::lwip)
Wifi Component CMakeLists.txt
# include paths of this components.
set(COMPONENT_ADD_INCLUDEDIRS include)
# source files of this components.
set(COMPONENT_SRCDIRS src)
# add this component, this will define a CMake library target.
register_component()
target_link_libraries(${COMPONENT_TARGET} PRIVATE AFR::wifi)
target_link_libraries(${COMPONENT_TARGET} PRIVATE 3rdparty::lwip)
target_link_libraries(${COMPONENT_TARGET} PRIVATE 3rdparty::lwip_osal)
