john1953 wrote on Monday, August 12, 2013:
When I add uart_set_divisors I get unresolved linker errors like:
arm-none-eabi-gcc -nostdlib -L"C:\cortex\all_cortex\Debug" -L"C:\cortex\CMSISv2p00_LPC177x_8x\Debug" -Xlinker -Map=“mcub_cortex.map” -Xlinker -gc-sections -mcpu=cortex-m3 -mthumb -T “mcub_cortex_Debug.ld” -o “mcub_cortex.axf” ./src/cr_startup_lpc17.o ./src/dip_switches_mcub.o ./src/fault_led.o ./src/lcd_idle.o ./src/lcd_main.o ./src/main.o ./src/node_stats_mcub.o ./src/tasks_mcub.o ./src/ui.o ./src/ui_menu.o ./src/ui_menu_board_list.o ./src/ui_menu_board_status.o ./src/ui_menu_generic.o ./src/ui_scr_adjust_params.o ./src/ui_scr_debug_data.o ./src/ui_scr_node_stats.o ./src/ui_scr_status_board_dips.o ./src/ui_scr_status_board_io.o -lall_cortex -lCMSISv2p00_LPC177x_8x
c:/code_red/redsuite_5.0.12_1119/redsuite/tools/bin/…/lib/gcc/arm-none-eabi/4.6.2/…/…/…/…/arm-none-eabi/lib/armv7-m\libc.a(lib_a-abort.o): In function `abort’:
abort.c:(.text.abort+0xa): undefined reference to `_exit’
c:/code_red/redsuite_5.0.12_1119/redsuite/tools/bin/…/lib/gcc/arm-none-eabi/4.6.2/…/…/…/…/arm-none-eabi/lib/armv7-m\libc.a(lib_a-signalr.o): In function `_kill_r’:
signalr.c:(.text._kill_r+0xe): undefined reference to `_kill’
c:/code_red/redsuite_5.0.12_1119/redsuite/tools/bin/…/lib/gcc/arm-none-eabi/4.6.2/…/…/…/…/arm-none-eabi/lib/armv7-m\libc.a(lib_a-signalr.o): In function `_getpid_r’:
signalr.c:(.text._getpid_r+0x0): undefined reference to `_getpid’
This seems to be due to the 64-bit division in that routine as when I comment out the division it seems to link fine. I am using Red Suite 5 on a LPC1778 with latest FreeRTOS.
Any thoughts on what is happening?
