# Is it advisable use an API ended in FromISR from a task context?
**URL:** <https://forums.freertos.org/t/is-it-advisable-use-an-api-ended-in-fromisr-from-a-task-context/20886>\
**Category:** Kernel\
**Created:** [July 4, 2024, 2:08pm UTC](https://forums.freertos.org/t/is-it-advisable-use-an-api-ended-in-fromisr-from-a-task-context/20886 "2024-07-04T14:08:30Z")\
**Showing post:** 2
**Author:** ![RAc](https://d3iykfbgfh8zhg.cloudfront.net/user_avatar/forums.freertos.org/rac/32/1389_2.png) [@RAc](https://forums.freertos.org/u/RAc)\
**Post date:** [July 4, 2024, 2:38pm UTC](https://forums.freertos.org/t/is-it-advisable-use-an-api-ended-in-fromisr-from-a-task-context/20886/2 "2024-07-04T14:38:09Z")
This has been discussed here several times before, eg here:
[FromISR from user space - Kernel - FreeRTOS Community Forums](https://forums.freertos.org/t/fromisr-from-user-space/8752)
You may want to use the search function to avoid redundant discussions.
Thanks!
_[View the full topic](https://forums.freertos.org/t/is-it-advisable-use-an-api-ended-in-fromisr-from-a-task-context/20886)._
