I was wondering if there’s an option in heap_5 for a different alignment for certain blocks (portBYTE_ALIGNMENT), I am working with Arm M55, or if there’s an extension library that implements this functionality.
Thank you!
Thank you!
I do not think there is but you can write a wrapper, something like this:
#define SIZE_MAX ( ~( ( size_t ) 0 ) )
#define ADD_WILL_OVERFLOW( a, b ) ( ( a ) > ( SIZE_MAX - ( b ) ) )
#define BYTE_ALIGNMENT 16
#define BYTE_ALIGNMENT_MASK 0x000F
typedef struct BlockMetadata
void * pvOriginalBlock;
void * pvUserBlock;
} BlockMetadata_t;
const size_t xMetadataSize = ( sizeof( BlockMetadata_t ) + ( ( size_t ) ( BYTE_ALIGNMENT - 1 ) ) ) & ~( ( size_t ) BYTE_ALIGNMENT_MASK );
void * myCustomAlloc( size_t xWantedSize )
size_t xAdditionalRequiredSize;
BlockMetadata_t * metadata;
void * pvOriginal = NULL;
void * pvUser = NULL;
if( xWantedSize > 0 )
if( ADD_WILL_OVERFLOW( xWantedSize, xMetadataSize ) == 0 )
xWantedSize += xMetadataSize;
/* Ensure that blocks are always aligned to the required number
* of bytes. */
if( ( xWantedSize & BYTE_ALIGNMENT_MASK ) != 0x00 )
/* Byte alignment required. */
xAdditionalRequiredSize = BYTE_ALIGNMENT - ( xWantedSize & BYTE_ALIGNMENT_MASK );
if( ADD_WILL_OVERFLOW( xWantedSize, xAdditionalRequiredSize ) == 0 )
xWantedSize += xAdditionalRequiredSize;
xWantedSize = 0;
xWantedSize = 0;
pvOriginal = pvPortMalloc( xWantedSize );
if( pvOriginal != NULL )
metadata = ( BlockMetadata_t * ) pvOriginal;
pvUser = ( void * ) ( ( uint8_t * ) pvOriginal + xMetadataSize );
metadata->pvOriginalBlock = pvOriginal;
metadata->pvUserBlock = pvUser;
return pvUser;
void myCustomFree( void * pv )
if( pv != NULL )
metadata = ( BlockMetadata_t * ) ( ( uint8_t * ) pv - xMetadataSize );
if( metadata->pvUserBlock == pv )
vPortFree( metadata->pvOriginalBlock );
Thank you Gaurav, I will look into it!
regards,
Katia
