I need help. I need to synchronize LED blinking between CC1310 (868) modules
Hi all. I need help. I need to synchronize LED blinking between CC1310 (868) modules.
Currently installed: Code Composer Studio (12.5.0)
With its help, I was able to upload a finished project: CC1310 Simple Blink
At the output, DIO_7 received a high output at 1 second intervals.
How can I achieve synchronization of the radio signal?
Would you please elaborate the problem you are trying to solve. Do you want to have a number of MCUs to start and stop flashing LEDs at the same time. If so, can you broadcast/send a command and each MCU can independently start/stop flashing? Or did I not understand your problem correctly?
