jacklen wrote on Tuesday, September 30, 2014:
hi,iam trying to install freertos on friendlyarm mini6410 and after the source code compilation .axf file has been generated and now i want to fuse it to sd card for installing it.please help
davedoors wrote on Tuesday, September 30, 2014:
If you are wanting to boot from an SD card then presumably you are going to need a separate boot loader, UBOOT or something similar. It is very specific to the hardware you are best asking the hardware vendor.
is there any tools for fusing directly ??? i mean without using sd card??
