It sounds like the output format is not correct. In the project options, select the linker category, then select the output type you require (intel hex, or whatever). You can select two output formats if this is what you require by selecting the "Extra Output" tab.
Did you start your project based on the existing AVR/IAR demo?
I’m not sure how much you will get done in the small amount of RAM you have availble.
