nobody wrote on Wednesday, April 06, 2005:
I have a heap_size problem compilating freertos for the pic18f8720. The C compiler shows the warning message ‘cannot fit the section’. The only solution that I found was to fit the heap_size at 251 bytes! The pic18f8720 has 4kbytes of RAM.
rtel wrote on Wednesday, April 06, 2005:
You need to modify the linker script to create a block large enough to hold the heap.
Take a look at the linker script 18f452.lkr found in the demo/PIC directory of the download. The block named BIG_BLOCK is where the heap goes.
Also take a look at the thread: https://sourceforge.net/forum/forum.php?thread_id=1255600&forum_id=382005
which notes a get around for variables that straddle the block boundaries.
