sureshthiraviam wrote on Wednesday, December 18, 2013:
Hi
I am working with the cortex - m0plus controller. when we optimize the code to -O2 we are getting the hardfault during the debug.
static tskTCB *prvAllocateTCBAndStack( unsigned short usStackDepth, portSTACK_TYPE *puxStackBuffer )
tskTCB *pxNewTCB;
/* Allocate space for the TCB. Where the memory comes from depends on
the implementation of the port malloc function. */
pxNewTCB = ( tskTCB * ) pvPortMalloc( sizeof( tskTCB ) );
if( pxNewTCB != NULL )
/* Allocate space for the stack used by the task being created.
The base of the stack memory stored in the TCB so the task can
be deleted later if required. */
pxNewTCB->pxStack = ( portSTACK_TYPE * ) pvPortMallocAligned( ( ( ( size_t )usStackDepth ) * sizeof( portSTACK_TYPE ) ), puxStackBuffer );
if( pxNewTCB->pxStack == NULL )
/* Could not allocate the stack. Delete the allocated TCB. */
vPortFree( pxNewTCB );
pxNewTCB = NULL;
/* Just to help debugging. */
memset( pxNewTCB->pxStack, ( int ) tskSTACK_FILL_BYTE, ( size_t ) usStackDepth * sizeof( portSTACK_TYPE ) );
return pxNewTCB;
I am getting the hardfault in the else part…
