It took me some time, but I started to obtain some experience with cscope and ctags.
I will try to keep this post updated from time to time, since I think it might help me (and maybe others) to have more efficient code navigating.
Currently I want to share my basic setup.
The information is gathered from this cscope tutorial and this ctags tutorial
After the installation of those components, in the source directory of the project I do
ctags -R *
cscope -R -b
- Now, I act according to this post and set the correspond environment variable:
export CSCOPE_DB=/foo/cscope.out
and I also add a reference to it in vimrc cs add $CSCOPE_DB
I also
:set cscopetaginside vim to make the cscope use the ctags indexes -
Finally, I locate myself in the source folder (This is important since all tags are relative to this folder) and I navigate from there. (i.e after
cdthe source folder I justvimand keep on from there)
This should be enough to make the indexes work. Some basic keys are
Ctrl-]to jump to a tag -
Ctrl-tto take a backward step -
:tsfor searching a tag. (i.e. yank a tag withywand then:ts Ctrl+R+"to see it’s refrences
