dlugi4 wrote on Wednesday, May 08, 2013:
Hi.
I need created from part of microcontroller code a dll. dll will be used by the .NET application. The microcontroller uses FreeRTOS. To create a dll I use the MinGW. Is it possible to use FreeRTOS Windows Simulator to create a dll? I converted the code FreeRTOS Windows Simulator from exe to dll, but call the function vTaskStartScheduler freezes .NET applications. Has anyone had a similar problem?
