andre-h wrote on Wednesday, November 07, 2018:
Hello
I am working on a LPC1758 using the GCC compiler with the MCUXpresso IDE. I want to setup a TCP/IP stack using FreeRTOS+TCP 2.0.7 and FreeRTOS v10.1.1. I am busy implementing zero copy drivers for the TCP/IP stack. I also statically allocate the network buffers using BufferAllocation_1.c
I would like to know if it is possible to pass a network descriptor that has been created not using the pxGetNetworkBufferWithDescriptor function to the TCP/IP stack’s event queue? Another way of phrasing the question would be if it the TCP/IP’s event queue can accept network descriptors that does not point to a buffer that is pre-allocated as part of the TCP/IP stack in vNetworkInterfaceAllocateRAMToBuffers?
