Now I would be very curious to see the contents of the struct pxIPPacket->xIPHeader.
That represents the IP-header of a packet.
Als the value of uxBufferLength, which is the number of bytes received.
pxIPPacket->xIPHeader .
ucVersionHeaderLength=0x00 Should be 0x45, or at least 0x4.
ucDifferentiatedServicesCode=0x01
usLength=0x0008 Should be at least 20
usIdentification=0x0406
usFragmentOffset=0x0100
ucTimeToLive=0x00 Should not be zero
ucProtocol=0x00u Expected 1, 2, 6, 17
sHeaderChecksum=0x0000
ulSourceIPAddress=0xa8c00000 168.192.0.0
ulDestinationIPAddress=0x0000c750 0.0.199.80
uxBufferLength = 0x2a 42 bytes received, that is possible
I can not make much of it.
I have only seen these kind of problems in case the memory shared with DMA was cached.
What does a received packet look like when it is just received, in x_emacpsif_dma.c around the macro iptraceNETWORK_INTERFACE_RECEIVE()?
As a test, could you change ucIsCachedMemory() to always return pdTRUE? just to see if the memories are still cached?
Good to hear, but this would mean that the memory provided by uncached_memory.c in fact is cached memory.
Does it mean that you can communicate now? Can you ping the board?
pucEthernetBuffer=0x00000000001ff4ca
I would be curious to see a memory-dump of the contents of this pointer pucEthernetBuffer , just the first 42 bytes.
Where can i find this?
Well, if it works now for you, i don’t need to look this up anymore.
One of the many windows in Eclipse is called “memory”, it can show you the contents of the RAM. Fill in the value of the pointer pucEthernetBuffer, and you will see the packet.
It looks like the CRC/length error is a false alarm. It is shown when xNetworkInterfaceOutput() calls usGenerateProtocolChecksum() with an ARP packet. It should only call it for IPv4 ICMP packets.
Could you make the following change in xNetworkInterfaceOutput() in NetworkInterface.c, around line 234:
- if( ( pxPacket->xICMPPacket.xIPHeader.ucProtocol != ipPROTOCOL_UDP ) &&
+ if( ( pxPacket->xICMPPacket.xEthernetHeader.usFrameType == ipIPv4_FRAME_TYPE ) &&
+ ( pxPacket->xICMPPacket.xIPHeader.ucProtocol != ipPROTOCOL_UDP ) &&
( pxPacket->xICMPPacket.xIPHeader.ucProtocol != ipPROTOCOL_TCP ) )
/* The EMAC will calculate the checksum of the IP-header.
It can only calculate protocol checksums of UDP and TCP,
so for ICMP and other protocols it must be done manually. */
usGenerateProtocolChecksum( (uint8_t*)&( pxPacket->xUDPPacket ), pxBuffer->xDataLength, pdTRUE );
I always find telnet an easy tool for testing TCP.
Here is a simple example: telnet.zip (2.8 KB)
In telnet_usage.c you see an example of how to use it.
The default port number is 23 ( see TELNET_PORT_NUMBER ).
A more complex tools is IPERF, which measures performance. iperf_task_v3_0d.zip (7.3 KB)
Please see iperf_config.h for an example of configuration parameters.
@htibosch ,
As far as I know, the only major difference in PS part between Xilinx MPSoC chips is that CG devices have Dual-Core A53 MPCore. The others have Quad-core.
I’m afraid, Ultra96-V2 does not have Ethernet (rj-45) port. I doubt that WiFi uses GEM.
I found this one in the list on Xilinx site: FZ3 Kit, with similar price. But it seems to require external JTAG like this JTAG-HS2.
I also asked Avnet and they offered to use SOM approach: Carrier + Processor
But is looks quite expensive
I have started exploring my new FZ3 board with an Ultrascale, with 4 x Cortex-A53.
Thanks a lot to @Maxim.Vechkanov because he helped me to get started much quicker than I would have done on my own. He seems very experienced with Xilinx FPGA’s.
Here are some things that I found, just for your interest:
That is much more than necessary. These are the number of descriptors that are reserved for the DMA. In a very fast sytem like UltraScale the following should be enough:
Note that received UDP packets are stored in a list of network packets, which belongs to a UDP socket. And then there may be packets traveling from the network interface to the IP-task.
The project uses BufferAllocation_2, which allocates network buffers by using pvPortMalloc(), whereas we wanted to use the uncached memory, BufferAllocation_1.c.
The latter allocates all necessary network buffers statically, at start-up.
I have an application running now, and the PHY is recognised as a Marvell. So I am as far as Philipp last reported.
I see you are working with tcp/ip stack on zynq ultrascale board. I m working in similar project, I use a ZYNQ ULTRASCALE XCZU7CG MCU ( precisely we use the R5 cortex ). I can’t send an UDP frame or receive it. In Tx mode , Stack try to send an arp frame but i don’t see any frame sent in wireshark. I use a freeRtos 10.2.1 stack. this is my dump memory for GEM register and PL390 below.
0x101004 frame status and length
0x0002CDEA frame buffer adresse frame length is 60 byte
Any Idea why the frame didn’t be sent and seen by wireshark ?
Any valid example was always welcome !
I suspect that the not alignment of our buffer can cause this issue. the buffer shifter by 2 bytes. can this be the source of our issue ?
other suspicion is that the dma don’t send all data or the phy doesn’t send the data, any way to debug this two module.
Hello khalil, yes I am working on a FreeRTOS+TCP driver for UltraScale+. And I need co-testers.
It needs a small adaptation to have UDP work on a 64-bit platform.
ARP, ICMP(echo), and TCP work fine already.
I will get UDP to work and post the driver (as it is) on this forum.
