williamjsell wrote on Sunday, April 24, 2011:
I tried to port freeRTOS over to the msp430f5529 platform from the existing msp430f449 freeRTOS demo; I am using Crossworks V2.0 as the dev environment; it was pretty straightforward, or so it seemed; but when I called the asm line “call #_prvSetupTimerInterrupt”, the call never returns; at first I thought this was the stack getting manipulated to vector to the first task, but the call to portRESTORE_CONTEXT is never reached, which means the stack should have the return address to the calling function. But this is not working and I cannot see the reason; Paul Curtis at Crossworks thinks this is something to do with the compilation being for the MSP430X series of processors which have a different idea of function pointers. To save myself some time figuring this issue, I thought I would check and see if anyone else has encountered a similiar problem; the new series of MSP’s from TI are getting very popular with the extended memory range and internal USB hardware, so it seems like a good thing to fix
thanks
-Bill
