FreeRTOS-PLUS-TCP: Repeated eNetworkDownEvent events
Hi TCP-newbie, thank you for your interest in FreeRTOS+TCP.
Here is a summary about the network-down events:
The function vCheckNetworkTimers() will be called in every IP-task loop. As long as one or more interfaces are not up, it will initiate a network down event.
  1. It will call FreeRTOS_NetworkDown() for a every interface which is down
  2. This function will send a eNetworkDownEvent to the IP-task
  3. It will check all endpoint of mentioned interface
  4. For each endpoint, bEndPointUp will be cleared
  5. For each endpoint vApplicationIPNetworkEventHook_Multi() will be called with the parameter eNetworkDown
  6. And then, most importantly, pxInterface->pfInitialise() is called to check the interface.
So it is normal that the down-event is repeated as long as pxInterface->pfInitialise() fails.
The interval at which the event is repeated can be configured with:
/** @brief Time delay between repeated attempts to
  * initialise the network hardware. */
#ifndef ipINITIALISATION_RETRY_DELAY
    #define ipINITIALISATION_RETRY_DELAY    ( pdMS_TO_TICKS( 3000U ) )
#endif
PS. there are two minor issues:
  1. The macro ipINITIALISATION_RETRY_DELAY is defined locally in FreeRTOS_IP_Utils.c, but it is never used.
  2. In FreeRTOS_IP.c, the macro definition uses pdMS_TO_TICKS(), and when applying, again pdMS_TO_TICKS()
In all newer code, timing macro’s have an extension _TICKS or _MS, which makes clear if pdMS_TO_TICKS() has to be called.
About the network interface. Many developers think that pfInitialise() will be called only once, right after start-up. That is not true.
The function xxx_NetworkInterfaceInitialise() will be called as long as it returns pdFAIL.
Here is an example, borrowe dfrom the STM32Fx driver:
static BaseType_t xSTM32F_NetworkInterfaceInitialise( NetworkInterface_t * pxInterface )
    if( xMacInitStatus == eMACInit )
        /* Initialisation is only done once. */
        if( ethernet_init() == pdPASS )
            xMacInitStatus = eMACPass;
        else
            xMacInitStatus = eMACFailed;
    } /* if( xMacInitStatus == eMACInit ) */
    if( xMacInitStatus != eMACPass )
        /* EMAC initialisation failed, return pdFAIL.
         * This interface will not get into a working state anymore. */
        xResult = pdFAIL;
    else
        if( xPhyObject.ulLinkStatusMask != 0U )
            xResult = pdPASS;
        else
            /* For now pdFAIL will be returned. But prvEMACHandlerTask() is running
             * and it will keep on checking the PHY and set 'ulLinkStatusMask' when necessary. */
            xResult = pdFAIL;
    /* When returning pdPASS, the stack will become active and
     * start DHCP (in configured).
     * Otherwise, this function will be called again. */
    return xResult;
If you want, you can ignore the repeated events like eg. here:
static volatile BaseType_t xServerCanStart;  /* Becomes true when the internet service can start-up. */
void vApplicationIPNetworkEventHook_Multi( eIPCallbackEvent_t eNetworkEvent,
                                           struct xNetworkEndPoint * pxEndPoint )
    static BaseType_t xLastEvent = -1;
    if( xLastEvent != ( BaseType_t ) eNetworkEvent )
        xLastEvent = ( BaseType_t ) eNetworkEvent;
        if( eNetworkEvent == eNetworkUp )
            xServerCanStart = pdTRUE;
    else
        /* Ignore this repeated event. */
