@tony-josi-aws Thank you for your inputs.
Using the patch shared I was able to communicate with Remote TCP server (tcpbin.com) and verify it using the PCAP. For static as you mentioned you set the value of xEndPoints[ 0 ].bits.bWantDHCP = pdFALSE and with that I used the IP as 10.0.2.15 which automatically gets set in application when ipconfigUSE_DHCP is used. But as per the description mentioned in the document as well in FreeRTOSIPConfig.h for ipconfigUSE_DHCP; this flag is to be set only when using DHCP server. So just wanted to understand the purpose of this flag because on setting xEndPoints[ 0 ].bits.bWantDHCP as False it works as Static and still ipconfigUSE_DHCP has to be configured as 1. Please correct me if my understanding is wrong.
