Well, I am not sure that a correct definition of ConfigTotal_HEAP_SIZE, in the FreeRTOSConfig file. Take a look in my screenshot and code in the end of this post
I saw that I had the heap3.c in the other directory: “C:\Users\Claudio Rosa.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\Source\portable\MemMang” , then I renamed the heap3.c as heap3.c.old and I added the heap4.c in this directory, and error messages were reduced, take a look:
The error messages:
Executing task in folder RastAtivos: C:\Users\Claudio Rosa\.platformio\penv\Scripts\platformio.exe run
Processing wiscore_rak4631 (platform: nordicnrf52; board: wiscore_rak4631; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/nordicnrf52/wiscore_rak4631.html
PLATFORM: Nordic nRF52 (10.4.0) > WisCore RAK4631 Board
HARDWARE: NRF52840 64MHz, 243KB RAM, 796KB Flash
DEBUG: Current (jlink) External (jlink, stlink)
PACKAGES:
- framework-arduinoadafruitnrf52 @ 1.10600.0 (1.6.0)
- framework-cmsis @ 2.50700.210515 (5.7.0)
- tool-adafruit-nrfutil @ 1.503.0 (5.3)
- tool-sreccat @ 1.164.0 (1.64)
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 32 compatible libraries
Scanning dependencies...
Dependency Graph
|-- SparkFun LIS3DH Arduino Library @ 1.0.3
|-- Adafruit BME680 Library @ 2.0.4
|-- SparkFun u-blox GNSS Arduino Library @ 2.2.25
|-- SX126x-Arduino @ 2.0.24
|-- ArduinoJson @ 7.0.4
|-- CayenneLPP @ 1.1.0
|-- PackPayload
|-- RAK12500
|-- RAK15007
|-- RAK1904
|-- RAK1906
|-- RAK4631
|-- RAK5801
|-- Wire @ 1.0
Building in release mode
Compiling .pio\build\wiscore_rak4631\FrameworkArduino\freertos\Source\portable\MemMang\heap_4.c.o
Compiling .pio\build\wiscore_rak4631\FrameworkArduino\freertos\portable\MemMang\heap_4.c.o
Compiling .pio\build\wiscore_rak4631\FrameworkArduino\rtos.cpp.o
Compiling .pio\build\wiscore_rak4631\FrameworkArduino\sysview\Config\SEGGER_SYSVIEW_Config_FreeRTOS.c.o
Compiling .pio\build\wiscore_rak4631\FrameworkArduino\sysview\SEGGER_SYSVIEW_FreeRTOS.c.o
Compiling .pio\build\wiscore_rak4631\FrameworkArduino\utility\AdaCallback.c.o
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\Source\portable\MemMang\heap_4.c:92:44: warning: character constant too long for its type
PRIVILEGED_DATA static uint8_t ucHeap[ configTOTAL_HEAP_SIZE ];
Compiling .pio\build\wiscore_rak4631\FrameworkArduino\utility\SoftwareTimer.cpp.o
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\Source\portable\MemMang\heap_4.c: In function 'pvPortMalloc':
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\Source\portable\MemMang\heap_4.c:275:13: warning: implicit declaration of function 'vApplicationMallocFailedHook' [-Wimplicit-function-declaration]
vApplicationMallocFailedHook();
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\Source\portable\MemMang\heap_4.c: In function 'prvHeapInit':
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\Source\portable\MemMang\heap_4.c:384:29: warning: character constant too long for its type
size_t xTotalHeapSize = configTOTAL_HEAP_SIZE;
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\Source\portable\MemMang\heap_4.c: At top level:
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\Source\portable\MemMang\heap_4.c:487:25: error: unknown type name 'HeapStats_t'; did you mean 'TaskStatus_t'?
void vPortGetHeapStats( HeapStats_t * pxHeapStats )
TaskStatus_t
Compiling .pio\build\wiscore_rak4631\FrameworkArduino\utility\adafruit_fifo.cpp.o
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\portable\MemMang\heap_4.c:92:44: warning: character constant too long for its type
*** [.pio\build\wiscore_rak4631\FrameworkArduino\freertos\Source\portable\MemMang\heap_4.c.o] Error 1
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\portable\MemMang\heap_4.c: In function 'pvPortMalloc':
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\portable\MemMang\heap_4.c:275:13: warning: implicit declaration of function 'vApplicationMallocFailedHook' [-Wimplicit-function-declaration]
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\portable\MemMang\heap_4.c: In function 'prvHeapInit':
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\portable\MemMang\heap_4.c:384:29: warning: character constant too long for its type
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\portable\MemMang\heap_4.c: At top level:
C:\Users\Claudio Rosa\.platformio\packages\framework-arduinoadafruitnrf52\cores\nRF5\freertos\portable\MemMang\heap_4.c:487:25: error: unknown type name 'HeapStats_t'; did you mean 'TaskStatus_t'?
TaskStatus_t
*** [.pio\build\wiscore_rak4631\FrameworkArduino\freertos\portable\MemMang\heap_4.c.o] Error 1
FreeRTOSConfig.h
#define configTICK_SOURCE FREERTOS_USE_RTC
#define configUSE_PREEMPTION 1
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 0
#define configUSE_TICKLESS_IDLE 0
#define configUSE_TICKLESS_IDLE_SIMPLE_DEBUG 1 /* See into vPortSuppressTicksAndSleep source code for explanation */
#define configCPU_CLOCK_HZ ( SystemCoreClock )
#define configTICK_RATE_HZ 100
#define configMAX_PRIORITIES ( 15 )
#define configMINIMAL_STACK_SIZE ( 600 )
#define configTOTAL_HEAP_SIZE 'heap_4.c' /* valor original ( 175000 ) */
#define configMAX_TASK_NAME_LEN ( 15 )
#define configUSE_16_BIT_TICKS 0
#define configIDLE_SHOULD_YIELD 1
#define configUSE_MUTEXES 1
#define configUSE_RECURSIVE_MUTEXES 1
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_ALTERNATIVE_API 0 /* Deprecated! */
#define configQUEUE_REGISTRY_SIZE 2
#define configUSE_QUEUE_SETS 0
#define configUSE_TIME_SLICING 0
#define configUSE_NEWLIB_REENTRANT 0
#define configENABLE_BACKWARD_COMPATIBILITY 1
// Erro na compila��o #define configUSE_DAEMON_TASK_STARTUP_HOOK 1
#define configSUPPORT_STATIC_ALLOCATION 0
#define configUSE_APPLICATION_TASK_TAG 1
#define configUSE_POSIX_ERRNO 1
#define configSUPPORT_DYNAMIC_ALLOCATION 1
/* Hook function related definitions. */
#define configUSE_IDLE_HOOK 1
#define configUSE_TICK_HOOK 0
#define configCHECK_FOR_STACK_OVERFLOW 1
#define configUSE_MALLOC_FAILED_HOOK 1
